Weltkrieg 11 deutsche Werkstatt
    Looking good, will be watching.
    Scott
    • grumpa
      • Jan 2015
      • 6142
      #17
      Hold on a second, do you mean to say you have a B.P. plus a Famo with trailer? Well I have a name for your Dio......"Jim's Jealous-Jealous-Jealous!!!"
      I will be watching you lucky dog!...........Cheers.....Jim
        I was a lucky boy at Christmas Jim.
        • monica
          • Oct 2013
          • 15169
          #19
          do you paint before you start or when you have finished Monica?
          with the tracks I,will paint when done,but not on,and do the weathering at the same time as the rest,so it all blends in o_O
          and to get the bend in them ,I wait till you know the glue has hold,but not set fully,
          and I tend to run some making tape on the outside so as you do bend them,it dose
          help to hold,until fully set,
            Cheers Monica I have already used Vallejo track primer on them before reading this. The tracks for this build are giving me a few headaches I can get one side to lock in but when I try to get the other ones to go it pops out. Needless to say I have not got a lot done today.
            • monica
              • Oct 2013
              • 15169
              #21
              it should be fine,just let the glue set a little longer,
              ok lets see if I,can help a little hear,what I,do is use double sided tape,on my board,then on top of that,place making tape
              sticky side up,
              the hard part is getting the first 4 or 5 together,I will hold them and its like a S,patten start at the closest point to you,and click in,
              then,push in the middle,part then the end,once you have a few together,push down onto ,the tape,so it holds,and against the ruler
              as your straight edge,then you should be able to hold the front ones with a finger and push the others on from the back,holding
              on a stile angle,so ends and center,push down and forewords at the same time,and after a few its just gets much easier whit each one,
              hope you get what I,mean,and its of help,
                Thanks for your time on this Monica I shall give that a go.
                • monica
                  • Oct 2013
                  • 15169
                  #23
                  glad to try and helpout on this one for you,
                  and I,do hope it dose work,once you get the hang its not so bad real,
                    Well after a week of messing around with these tracks I have decided not to use them. I have ordered some metal ones instead and will have to wait a week or so for them to arrive.
                    In the mean time I have decided to start the Famo. Pictures will follow once I get going
                      You do realise that in starting the Famo, you are personally responsible for me becoming paid and broke next pay day.........
                        HAHHAHAHA I am sure you will get great pleasure out of it Graham.
                          Nice work going on here Terry
                            Thanks Ralph
                              If this kit keeps gong the way it is it will be a dream to build. The first few pieces of PE have been a bit fiddly but that is PE anyway. The chasis is now awaiting the the paint booth treatment.
                              • monica
                                • Oct 2013
                                • 15169
                                #30
                                the engine has turned out well ,do like the color of it,
                                and the added PE,dose make a differences to it as well,
