My first ever building ( scratch built )
  • Robert1968
    • Mar 2015
    • 3596
    well I've decided after watching Ralph's build to build my own building for my ""out of gas out of time"
    I'm going to build a simple 2 storey townhouse which will have some damage to the roof walls and floors.
    It's going to be my first ever scratch building but with Ralph's advice and help I think it could work
    I'm using 2mm plastic card ( got 6 sheets in a deal) and I got Tamiya brickwork transfer.
    I've used the 9mm to 1ft scale which should be 1/35.scale
    I have ref pics to work from
    Comments welcome
  • meggsy
    • Jun 2011
    • 421
    I'll be watching this always wanted to do a scratch build but never had the nerve to try
      Go for it Robert. I am sure Ralph will be happy to see someone have a go after all the hard work he put into his excellent tutorial.
      • Robert1968
        • Mar 2015
        • 3596
        Thanks Steve, glad to have you on board.I'm hoping to make it the best I can ( 1st time ) and as I'm waiting for my compressor etc I can't do any spraying or painting so I'm just trying to get as many jobs done as possible so I'll be spraying overtime in a few weeks.mi plan on getting this done in maybe 2/3 weeks.
        I'll try doing a best thread as possible on how I do things.
        Robert
        • Robert1968
          • Mar 2015
          • 3596
          Thanks Graham I'll do my best to keep Ralph's tutorial close ( I'm aiming big to match him though)
          Robert
          • monica
            • Oct 2013
            • 15169
            very glad to see someone using,Ralph's tutorial,
            and looks like a nice start so far,
              It is going to be great watching this Robert.
              You are already off to a great start.
              And remember you can ask as many questions as you like.
              • Robert1968
                • Mar 2015
                • 3596
                Thanks Monicaband glad to have you onboard ( I'm trying to follow Ralph's ideas and tutorial as best I can ( not to copy but have my own flair on it ) think my wallpaper may be nicer( Hahahahahaha)
                However he is bloomin good at what he does!!!
                Regards
                Robert
                • Robert1968
                  • Mar 2015
                  • 3596
                  So if I pack it all in a Jiffy bag ( send it to you you build it etc etc ( send it back and I say ta da look what I've done ( Hahahahahaah)
                  Thanks Ralph I'm sure if I follow the guidelines and read the tutorial I'll be fine. next is the side of the building to mark out and cut
                  Regards
                  Robert
                    Looks like you are in good hands Robert, look forward to watching the progress. Derek
                    • Robert1968
                      • Mar 2015
                      • 3596
                      Step two
                      Cutting the windows out and door / side wall.
                      This took an eternity and still got 4 windows to cut out ( 2mm plastic board takes forever but with new blade it wasn't all that bad. This all from 1 A4 sheet of 2mm plastic card
                      I'll get the rest cut out tomorrow after work
                      Pics . comments welcome
                        This is looking interesting, got my chair, my whskey and popcorn, I'm here for the duration
                          I shall be here watching as well you will have fun doing this I know I did when I did my barn.
                            Looking good.
                            It does take a while to cut through 2mm.
                            • spanner570
                              • 15432
                              Robert, with you deciding to use plastic card, you will find it will probably warp as you are cutting out the openings.
                              To get over this, once you have completed all the cutting on the face, turn the piece over and gently scour random cuts (more like heavy scratches) on the reverse side. This will straighten out your wall.
                              I hope this little tip will be of some use to you.
                              Ron
