My first ever building ( scratch built )
    This is beginning to look really good Robert. Hats off to you for having a go, really must pull my finger out.
    • monica
      • Oct 2013
      • 15169
      #62
      great progress so far on this one,Robert,do like the floor boards,as said looking like they should,,
      • Robert1968
        • Mar 2015
        • 3596
        #63
        Been busy with odd shifts at work so not too much time on the model front. Got the floor done after a few head scratches on how to do it. I made a X form then CA this to the walls and then doubled up on the beams then started Laying odd floorboards. I'll need to adores the doorway once all this dry . I thought of the partianing walls and well I could have gone down the route of 2mm plastic but thought use strong card and brace with wood internally ( two walls ready for decor
        With the hard card braced this was another support for the roof beams and so cracked on with that.The roof will have tiles on top of the wood
        I've ordered some ballast which will be for rendering for the outer walls ( thanks Ralph on advice there )
        It's no where near complete but some pics
        Comments welcome
          Coming along real well.
          Do like you are adding internal walls.
          • Robert1968
            • Mar 2015
            • 3596
            #65
            Thanks Ralph ( still using your ideas but invention of a few myself ( if it works )
            Regards
            Robert
            • monica
              • Oct 2013
              • 15169
              #66
              coming along very nicely,do like the internal wall,as well,
                Looking good,
                • Pikeman
                  • Feb 2016
                  • 1312
                  #68
                  Originally posted by \
                  Well got me my last four/ five Windows cut out ( took me half the time but still nursing a throbbing thumb.
                  Next step I'll look at addressing the brickwork pattern ) Tamiya pre painted then I might attempt dry fitting the two pieces before I start on the wall partitions.Ill start making some tiles from the 2mm pieces cut out from the windows.
                  I have to build also framing for the Windows and ledges ( I'll be using 2mm plastic card and also wooden rods but I'll post pics of these once complete
                  Pics
                  Comments welcome
                  [ATTACH]147867[/ATTACH] [ATTACH]147868[/ATTACH] [ATTACH]147869[/ATTACH] [ATTACH]147870[/ATTACH]
                  Pics
                  Comments welcome
                  Looking really good Robert.
                  The build is really coming together nicely and I must say you have the patience of a saint with those tiles
                  • Robert1968
                    • Mar 2015
                    • 3596
                    #69
                    Looking good,
                    Thanks Ken I just can't wait to get some colour on those walls and start staining that wood ( still waiting on my Compresor coming in. I have made over 200 tiles for the roof and I'm thinking should I start at the top of the roof to lay ( never laid tiles before)
                    Regards
                    Robert
                    • Robert1968
                      • Mar 2015
                      • 3596
                      #70
                      Thanks Stuart
                      As I said to Ken I gave over 200 tiles to lay but think I'm going to dark stain the roof wood first ( paint thinner coats of wood colours to stain the wood.
                      I've never laid roof tiles in my life but looking from ref pics it's start at the top row and overlap?
                      Regards
                      Robert
                      • bazers
                        • Oct 2013
                        • 2611
                        #71
                        Looking good.
                        • geegad
                          • Mar 2010
                          • 2329
                          #72
                          outstanding work really like that sheet brick work really does work well look forward to seeing more of this
                            Thanks Stuart
                            Regards
                            Robert
                            You need to start with the bottom layer of tiles and work your way upwards.That way you overlap the tiles by putting them on top of each other
                            • spanner570
                              • 15441
                              #74
                              Just to add a bit more to Ralph's post.
                              Start in the bottom right corner with a full tile and work along. The second row will start with a half tile, also in the bottom right corner. Then away you go - full, half, full.....to the top.
                              ..........also, as it's tiles, you can get away with showing about 2/3rds. of the tile when covering with the next row. (If it was slate, it would be a half lap) Keep about a 4" scale overhang going up the brickwork and the same along the bottom. Don't forget to stagger the tile joints. Also, don't worry what will happen with the tile spacing when you reach the top, just keep the tiles the same overlap all the way up.
                              All looking good.
                              Ron
                              • Robert1968
                                • Mar 2015
                                • 3596
                                #75
                                Thankyou guys for all the positive comments. I'm really enjoying building this. I will prob do another building ( poss an outside loo, but not sure if I can make a toilet ( poss out of clay?
                                I may have to redo my tiles as I have noticed with the 1/35 scale they look a bit small to scale ( put a soldier by a tile and looks too small.
                                More measuring and more cutting but hope to get tiling done by Friday
                                Regards
                                Robert
