Golan patrol
    Golan patrol
    Hi all, ihave just begun the construction of a new diorama. It will be set in the golan heights, I am in the process of constructing a destroyed building, might actually do one more after this. It is made from 5mm foam board, here is my progress so far.
    Scott
    This is the effect iam going for.
    • 22785
    Nice idea Scott and a great start. Is this from the Yom Kippur war, or a later date?
      Set next year, I have an idea but I need to fully work out the details yet. I will be using my merkava III and a bmp 1. Otherwise I am not sure yet.
      Scott
        • 22785
        Scott
        That was going to be my next question. Is a Merkava involved, but you've already answered it
          Where do you get your foam board from Scott?
          • colin m
            • 8781
            • Colin
            • Stafford, UK
            Anywhere else except a model forum, and you might cause some confusion with those words...
              I bought two packs of A4, 5 sheets each pack from the range, they cost me ยฃ10 total and I can get two buildings out of each pack.
              Scott
                Hi guys some further progress on the structure hope you like it.
                Scott
                  Ahhh, is this the paper covered foam core? I use that as a base material.
                  Lots of YouTube videos show an uncovered foam that can be carved or scribed. I assume this is a high density foam like insulation but I don't know if it is available in thin sheets.
                    That's the one graham foam core.
                    Scott
                    • monica
                      • Oct 2013
                      • 15169
                      Nice idea Scott,this is looking good,do like the battle damage to it as well,
                      maybe Graham ,the one you are thinking of is called depron, is what I use,mostly use to make planes out of ,
                        You have my interest.
                          Thanks kind folks, on the areas of bare grey foam I will inscribe a brick pattern into these areas, then they will get a coat of pva to seal the foam. Once this is complete I will stiple the whole structure with filler and paint once dry.
                          Scott
                          • Snowman
                            • Oct 2014
                            • 2098
                            Looking the business!!
                              Thanks snowman โ›„ all the grey foam has been sealed, once its dry I will stipple on the filler.
                              Scott
