Truck 'Loading Bay' Diorama WIP
  • tiking
    • Jul 2006
    • 1691
    #16
    Originally posted by grumpa
    What a mind you have Charles  Detail is amazing as is your eye for realism, you take notice of the un-noticed and are doing a superb job of it so far..........Jim
    Thank you kindly Jim.
    • tiking
      • Jul 2006
      • 1691
      #17
      The formboard before and after. I am removing the first layer as this has the material I am using is sandwiched between two cardboard paper. Removing the layer is very easy. I just take a sharp hobby knife and carefully peel off the paper.
      This is what it looks like after I remove the paper backing:
      The steel beams. I painted them blue.
      The back of the second wall backing was done using the same method as the front.  I used only half of the wall. I did not want to use the entire length. So I did it this way.
      This is how the wall looks now, when it is setup. I think it is starting to look like something.
      These will be the corner protective pillars that will be used at the entrance of the second entrance of the industry building:
      I decided to make air vents out of these. Yes. I tend to use whatever I have on hand, as to not spent too much money.
      I am going to use these to kit-bash/scratch built some Air conditioners. We shall see how that goes.
      These, I will use to scratch built some flood lights:
        • 18271
        Like the look of this one I think I will tag along for the ride.
        Great work and the detail it fantastic.
        • takeslousyphotos
          • Apr 2013
          • 3900
          #19
          Superbly detailled. That doorway looks 10% realistic.
          • tiking
            • Jul 2006
            • 1691
            #20
            Thank you Ian. appreciate the company.
            • tiking
              • Jul 2006
              • 1691
              #21
              Only 10% realistic Peter???  Thanks regardless.
              • takeslousyphotos
                • Apr 2013
                • 3900
                #22
                That's because I can't type ........... Give yourself another 90% and a biscuit. It looks superb.
                • Snowman
                  • Oct 2014
                  • 2098
                  #23
                  Dead cool & very realistic! B|
                  I like your style! ^_^
                  • tiking
                    • Jul 2006
                    • 1691
                    #24
                    HIHI!!! IT was a joke from my part. I knew it was mistype. Thanks again.
                    • tiking
                      • Jul 2006
                      • 1691
                      #25
                      Thanks Snowman.
                        • 22770
                        #26
                        And I'm sure those little bits from the spares box will turnout to look just like real air conditioners Charles, outstanding work so far.
                        • tiking
                          • Jul 2006
                          • 1691
                          #27
                          I am hoping they will budding.
                            Wonderful mind you have their Charles and unbelievable skill to bring your ideas to life too.
                            • tiking
                              • Jul 2006
                              • 1691
                              #29
                              Thank you kindly. We'll see if what was in my mind, really was worth it.
                              • Steve Brodie
                                • Sep 2014
                                • 4652
                                #30
                                thats fricken superb
