Truck 'Loading Bay' Diorama WIP
  • monica
    • Oct 2013
    • 15169
    #76
    great detailing work,Charles,
    • tiking
      • Jul 2006
      • 1691
      #77
      Originally posted by 0ne48thtel
      This is just getting better and better Charles your eye for detail is so inspiring.
      Thank you kindly.
      • tiking
        • Jul 2006
        • 1691
        #78
        Thank you M.
        • tiking
          • Jul 2006
          • 1691
          #79
          I apologies for the bad pics. But when the diorama is completed, I will take better ones. These are just WIP as you can see:
          The bay door 'open & close' mechanism painted and ready to mount on the inside wall:
          I scratch built a drainage pipe that will be mount between both, the brick and concrete bay walls:
          I have added side roof strips to all sides of the front facing building and painted them blue:
          I scratch built a canopy for the second docking bay. I thought it was necessary and adds interest to the rest of the scene.
          I used cardboard corrugated roofing which made the job easy and simple. This was later glued onto the styrene piece that was the canopy.
          I used my trusty nuts and bolts for the areas that were going to be mounted to the wall. As you can also see, I made some bracing as well.:
          The canopy mounted in place. I think it looks ok.
          I decided to redo the concrete tarmac. I knew the ground did not look right, and this I was told should be perpendicular to the building and not at an angle as it is now. So I am trying to see if I can rectify my mistake by hiding those grooves. We'll see if it works.
          • rocko4346
            • May 2016
            • 34
            #80
            WOW!.......I think I'm gonna quit modeling after seeing your work lol
            • tiking
              • Jul 2006
              • 1691
              #81
              Thanks for that, although I have seen better work than mine. But I appreciate the compliment.
              • tiking
                • Jul 2006
                • 1691
                #82
                The Bay door mechanism device is now mounted.
                • tiking
                  • Jul 2006
                  • 1691
                  #83
                    Absolutely beautiful weathering and detail!
                    I love the more 'normal' scenes and this is great
                      You have a supernatural eye for detail my friend
                      • tiking
                        • Jul 2006
                        • 1691
                        #86
                        Glad to hear it Matt. Thank you.
                        • tiking
                          • Jul 2006
                          • 1691
                          #87
                          Thank you kindly. Detail is my friend. :
                          • monica
                            • Oct 2013
                            • 15169
                            #88
                            just plain great work going on with this one,
                            how did you make the brackets for the drain,
                            and were and what scale,bolt/nuts you use plz,just have to ask,loving this build,
                            • tiking
                              • Jul 2006
                              • 1691
                              #89
                              Hi M. They were scratch built. the nuts & bolts are 1/35 scale of various sizes. You can get them from MENG. You get a whole lot. Worth the buy. So, they do work with 1/24, depending on the sizeof the model you will be working with.
                                • 22770
                                #90
                                I'm loving watching this one come together Charles, great skills and scratch building
