Truck 'Loading Bay' Diorama WIP
  • tiking
    • Jul 2006
    • 1691
    #91
    I got the drain pipe in place. Yes. It is a little tight fit but it works. I have seen such fittings in very tight places. So I am not outside the norm.
    Starting to add the little details both inside and outside. the concrete bay. Addind signs and graffiti around the bay. Also starting to add small scrape here and there.
    I added the Bay Dock numbers on both docks.
    I have now corrected the concrete ground, so it is perpendicular to the buildings. Took some spackling but I got it there.
      • 22770
      #92
      Stunning work
      • tiking
        • Jul 2006
        • 1691
        #93
        Thank you.
        • tiking
          • Jul 2006
          • 1691
          #94
          I decided to redo the wheel guides. I thought they were too small in diameter. So I decided I had to scratch built them from Styrene. There are several design types but the one in the picture I posted below, is the common one.
          My version:
          This is the design I am basing my version on:
          The most difficult in building this guide was getting the angle right. I had to cut three rod sections at an angle to get the curved 90 degree angle that you get in some of these guides. The one in the first prototype picture fortunately has a smooth one flow curve section all the way through. But I am modeling after the above, which has angle sections instead of the smooth curved version in the picture.
          • tiking
            • Jul 2006
            • 1691
            #95
            The finished model. I think it looks better than the one I had earlier:
            Still continue to add details. Added a fire extinguisher to the docking bay:
            The mounted extinguisher on the side of the bay door:
            • tiking
              • Jul 2006
              • 1691
              #96
              Decided to add an old two-wheel cart on the dock. Added interest:
              Most wonder how I weather certain normal areas in my dioramas. Well. Nothing new or fantastic. I use real dust or dirt that I gathered from the ground at my work place. I even used dried mud from my neighbors farm yard. They are the best.
                • 22770
                #97
                Amazing work Charles, and as you say the new wheel guides look even better. Is the sack barrow hand made or a kit ? because it looks so real.
                • tiking
                  • Jul 2006
                  • 1691
                  #98
                  It is a kit. Don't remember but it came in another kit that I bought some years back but I don't seem to remember. Will let you know, when I figure it out.
                  • monica
                    • Oct 2013
                    • 15169
                    #99
                    stunning work ,Charles,each time I look see more and more detail,that is just superb,
                    all the signs,and bits and bobs real make this one,and plus you cannot,copy dirt,
                    and by using the real thing,cannot go wrong,
                    • tiking
                      • Jul 2006
                      • 1691
                      #100
                      So true M. Nothing beats the real thing.
                      • tiking
                        • Jul 2006
                        • 1691
                        #101
                        Forklift WIP:
                        Did some detail work on the forklift to give it some character. This is a Dinky toy model I bought at my local grocery store. The price was 'ok' and on top of it, it is 1/24 scale. To my surprise this model is pretty close to the real thing in accuracy. So I did not have to do too much extra work to get it to look descent. I added the hydraulics, strobe, extra lighting and cabling bind to the framework of the forklift.
                        Made a lock for one of the opening, which I'not too sure what it is used for; but according to my prototype pic, it has a gas-tank lock on the right side of the chassis. So I made it to look like the one in my pic.
                        Added some small details to the steering wheel:
                        Scraped away the extra stud that was on the forks:
                        Added an extra link from the steering wheel to the base of the forklift floor:
                        • tiking
                          • Jul 2006
                          • 1691
                          #102
                          Since this forklift was missing peddles, I scratch built a pair:
                          An over view of the forklift ready to paint:
                          I decided I will be making a sign for this building. I saw this children's alphabet with magnets on the
                          back to be placed on a refrigerator. I chose the letters I wanted and removed the magnets from the
                          back.
                          • tiking
                            • Jul 2006
                            • 1691
                            #103
                            Letters painted, weathered and mounted. I am still contemplating if I should have done it any other way:
                            The forklift painted and weathered. Looks much better than in its original state. I see I forgot to add the logo before weathering(Darn it!!!) See if I can still add it.
                            • tiking
                              • Jul 2006
                              • 1691
                              #104
                              used some kind of grease( don't know what kind) Otherwise, I usually use machine grease, mixed with black paint. Then I just apply it on the areas that has it on the real model. Like on the rack below:
                                Excellent work Charles
