Boris, don't feed the bears.
    Nice work so far Monica, looking forward to how this one pans out
    • monica
      • Oct 2013
      • 15169
      #17
      Originally posted by Ace
      Ambitious and clever; I like your bears!
      ta Neil,it is a bit ambitious,and I hope to pull it off,
      Originally posted by grumpa
      Great start on the bears, adding fur on them will surely add to the realism and as an added bonus it will cover seams and surgery scars
      P.S. cute toesies
      ta Jim,that,s the whole idea,as there will need to be size adjustments as well,in the length of the belly ,and its a good way,
      to cover the surgery,
      ta Tommy,that makes two of us,hoping ,I can pull it off,
        Thats a cracking idea Monica
        • monica
          • Oct 2013
          • 15169
          #19
          ta Scott,real glad that you like my idea,fingers crossed,
          • monica
            • Oct 2013
            • 15169
            #20
            well a start to putting him together,
            yes I know he looks a real mess so far,but need to start some were,
            once that ,green stuff,is dry and I,can then shape him a little better,
            but need the basic shape to do that,also need to lengthen the neck,as well,
            but once again,need it set before I,m,able to do it,ops:
            I,m liking how he is looking so far,not to bad ,but still a lot of work to be done,o_O
            • monica
              • Oct 2013
              • 15169
              #21
              well second,bear,very much easy ,than first to do,
              to alter his head and ,neck,cut off drill/pin,then green stuff,to shape,
              had a little play with doing fur,the camera helps,as it show,s more than your,
              eyes pickup,and I can see need to do ,the fur a lot closer togeather,but give,s
              me the right idea,
              well hope you like the progress so far,
                • 22770
                #22
                I really like the idea Monica, and some cracking work with the Bears.
                • monica
                  • Oct 2013
                  • 15169
                  #23
                  ta Ian,I do real appreciate it,as I ,know one still look,s oh my,
                  but should turn out all right,and will,be nice to see the transformation,of it,
                  • monica
                    • Oct 2013
                    • 15169
                    #24
                    ok I know you all ,are probably thinking what a mess ,or load of junk,
                    as I had to go out all day,it let the green stuff set,harden or what ever it dose,
                    so I was able to start to refine the shhape,of him,tonight when,I got home,
                    and placed his,head and made ,the neck a little stretch out,move into the possition,
                    in the oic,and still need to angle his hands as well,o_O
                    I think he is looking much better,and still a lot to do with them,both,
                    hope your liking it so far,
                    • stillp
                      • 8093
                      • Pete
                      • Rugby
                      #25
                      Could you use flock to simulate the fur Monica?
                      • monica
                        • Oct 2013
                        • 15169
                        #26
                        I,think you could,Peter,but would not real have death or,texture to it like fur but a good idea,
                        • monica
                          • Oct 2013
                          • 15169
                          #27
                          well some more done to these,s two guys,
                          maybe not the best looking things,but I think its working,as it dose,
                          give the look or fur,and add,s some death to them,can only do a bit at ,a time,or you flatten what your done already
                          well do hope you like them so far,
                          need to let dry,so more tomorrow morning,
                            I'd have used faux fur Monica. A thin mix of PVA glue & water would keep the pile looking in scale.
                            • stillp
                              • 8093
                              • Pete
                              • Rugby
                              #29
                              Now you have the 'shape' of the fur, some flock would give a more 'furry' finish than paint, surely? I'm sure I've seen some flock that has quite long fibres, a bit like static grass.
                              • monica
                                • Oct 2013
                                • 15169
                                #30
                                ta,Patrick,Pete,gives,me some think to research for next time,as its good to be able to have options,when doing things,
