Amazing work Peter. :thinking:
Wardell Bridge
YES! I love everything!!!
I also love the old-school point to point electronics and etched pcb's! :smiling3:
I still do that from time to time with some of my home projects for fun, although most of my electronics I design and build are surface mount stuff but it'll never look as good as a hand drawn pcb with a wire loom!
One question though. The bridge control panel. Is it a real one you've refurbished or is it a replica?
Whichever it is it looks stunning and very cool - and accurate!!!Comment
Thank you @kpnuts, rickoshea52, @Polux, and papa 695 for your :thumb2:
__________________________________________________ _____________________________
I still do that from time to time with some of my hope projects for fun, although most of my electronics I design and build are surface mount stuff but it'll never look as good as a hand drawn pcb with a wire loom!
The console is a disused real one that has been converted to operate a model of the bridge from which it came from. So in affect, the console will still be in use.Comment
Late last year the council put in a new pathway along Bridge Street. Even though the console is for a bridge pre 1995, I decided to add the 2017 addition to the landscape. A sort of bridge across the times project.
Measured this pathway, made notes, and took many photographs. Then proceeded to make a model of it.
Fantastic work!
You're not an architectural modeller by trade by any chance?
You're certainly more than qualified!Comment
No, I am just a first time modeller that seems to have some transferable skills to this new creative genre.
There is a house partly within the display area. I took some photographs and figured out its dimensions.
Building the house from scrap timber, Masonite, Perspex, and matchsticks.
Thank you Snowman for your :thumb2:
Had a bit of a challenge with the roof, especially since the house is cut off at a diagonal.
Painted some figurines and added one to the house. She is watching her world slowly come together. Hope she will be pleased with it :smiling4:
Built a five LED sequencer, one light per room. One light gets swapped for another every 20 seconds, as if someone is moving from one room to the next.
The mighty 555 timer and a 4017 decade counter - my dear old friends! :smiling:
It's funny how old CMOS technology is still being used today despite all modern microcontrollers and SMD technology.
I've mostly gone over to pure SMD designs with microcontrollers and FPGA today but every now and then a project calls for through hole components and CMOS technology!
I'm soon (-ish) going to build (I hope) a U.S.S Enterprise 1/500 (the Star Trek one) and I'm pulling out all the bells and whistles for that one. It's going to be driven by custom electronics and possibly also remote controlled via Bluetooth and an Android app, just for the fun of it.
Hand soldering 0402 leds and resistors is a tricky business but they can be hidden in very small objects and I don't want the leds to stick out on the model.
I really love your approach to diorama modelling and I really appreciate you taking the time to document the whole process for us to enjoy! :thumb2:
In a few months I'm also starting to build my large Schwerer Gustav diorama and I wasn't going to do any electronics simply because they had a strict no light discipline in order not to be bombed by the Russians, but it would be cool to add at least some light elements? Needs a lot of thinking this...Comment
Hello @Jens Andrée. Yes I am old school, mainly because I gave electronics away in the late 1980's. It is only this project which has me back to it. I am just using my old knowledge (it's all I got). I am not that interested in electronics anymore. Though I will be updating myself sometime this year with the Raspberry Pi for another interactive display for the museum.
I have a question:
I am about to start filling in the spaces of land fill with foam board. What is a good material to use to seal the foam so I can paint it, glue grass, and insert trees?
I have experimented with water-based wood filler. it dries hard, but seems a bit fragile.Comment
If you need some Raspberry Pi support then just ask when it's time!
Ordinary PVA, or a bit watered down PVA, is a great and cheap sealer for foam. If you want a specific texture you can use air drying clay like DAS or similar.Comment
