Started the base work,loads to do but it's going ok so far.
The fence is there so I know where the walkway is between the fence perimeter where the guards patrol.
Hope you like the look so far.
taking shape real well,Stuart,liking this one,
had the same question as,Colin,about the,fence,as you do not lose,
to much advisability with it,
would you have any more detail,about it what,gauge it is,?
Thank you for your kind words Monica
The fence is fine wire mesh grill on a roll 3m x 500mm x 2 mm about £12
Med and course available same size rolls different mesh size.
Hope this helps
It's a perfect size for 1/35 gonna use it on more kits
Hope this helps
ta for the help,info,on the mesh,Stuart,so I ,thinking the 2mm is the hole size,?
would you still have the evilbay link at all,make it a lot easy to find,
Hi Scott cheers for the kind feedback,the base is foam board I used this as I have a lot of posts to go on the base and it is easy to insert them into the soft foam.
Awesome, I will remember this for when I start dio's.
