Started on the base for my shilka.
Florist's foam cut and shaped by hand. Glued to plaster base and coated in tinted watered down white glue, then Vallejo earth and desert spotted on and brush blended.
[ATTACH]288858[/ATTACH]
Various scenic sands scatterd on and worked into glue. Airbrushed With AK sand and gravel fixer. One side would not glue down ( has now) so that side next.
[ATTACH]288859[/ATTACH]
Had to try a test fit, suspension and tracks working well. May add some weights to the inside to press down
[ATTACH]288860[/ATTACH]
