Good evening to you all! Just the title for know and the sketch of the plan! Rest will follow! Cheers Danny
DAK
GuestTags: None
Danny
Great to have you on board. Is there any room left on the lounge carpet with that dio of yours laid out?.:smiling3:
Steve -
So a little bit of a background about my dio! This was started 13 months ago! I have completed multiple builds that I will use for the dio and a 119 figures! Its too many pictures to post so i guess i only will post the final steps! Currently working on the base ! Will try to figure it out how to use this forum and tomorrow I will upload them ! Thanks for joining and following cheers DannyComment
So thats how the base began![ATTACH]297626[/ATTACH][ATTACH]297627[/ATTACH][ATTACH]297628[/ATTACH][ATTACH]297629[/ATTACH][ATTACH]297630[/ATTACH][ATTACH]297631[/ATTACH][ATTACH]297632[/ATTACH][ATTACH]297633[/ATTACH][ATTACH]297634[/ATTACH][ATTACH]297635[/ATTACH][ATTACH]297636[/ATTACH][ATTACH]297637[/ATTACH][ATTACH]297638[/ATTACH][ATTACH]297639[/ATTACH][ATTACH]297640[/ATTACH][ATTACH]297641[/ATTACH][ATTACH]297642[/ATTACH][ATTACH]297643[/ATTACH][ATTACH]297644[/ATTACH][ATTACH]297645[/ATTACH]Comment
Hi Gern thanks for joining and following this build ! the scale is 1/35 the display case size W 100cm L 175cm H 35cm further updates follow tonight ! cheers DannyComment
Johnnie thanks for the support and the kind words unfortunately MM shut down but these guys are kindly accommodate us! So thanks for that!Comment
[ATTACH]297873[/ATTACH][ATTACH]297875[/ATTACH][ATTACH]297876[/ATTACH][ATTACH]297877[/ATTACH][ATTACH]297878[/ATTACH][ATTACH]297879[/ATTACH][ATTACH]297880[/ATTACH][ATTACH]297881[/ATTACH][ATTACH]297882[/ATTACH]Comment
Hi Daniel, great that you joined too and brought your fantastic dio with you.:thumb2:
With the base starting to come together, the size of it all is truly impressive.
Following with interest.
FernandoComment
Hi Fernando thanks for your comment and also for the continuous support! Lot more to come stay tuned regards DannyComment
