Think you should mount this on its own base Richard. When you did the comparison photo WOW !
They didn't expect this - Marines at Peleliu
Thanks Andrew.
Thank you too Ian.
Scottie/Paul, not as tiny and clean as yours though.
Today is rest day and letting the metaliser cure. Then I'll think about how to cast it. Someone has asked me to also cast the Mk5 Jungle Enfield....it's so flimsy I don't know if the resin is tough enough for the tiny barrel.
RichardComment
Hi Guys,
I finally solved a way of casting the Type 92 and first started of by plugging any holes that would plug and prevent the cast from being extricated. I used white glue to seal with a thin membrane.
Then I placed escape funnels in places that could be a trap for bubbles gluing thin rod. Then I fitted a small portion of the gun into plasticine.
Made a reservoir with card and sealed all gaps with white glue.
Poured in the two part mix of RTV into the first half...after curing, pealed the plasticine off and poured in the other half to produce what is below. You will notice I had put in some locking joints by poking the plasticine prior to pouring the RTV.
Mixed up the resin and using a syringe, squirtered the mixture into the mould and left it to cure. This takes roughly about 8 hrs.
Whatever extras I had from the mixtures I made moulds and casts for the marine knapsack. You can see the casting still imbedded in the mould.
It's out out of the mould and looks pretty good. It does suffer from a large bubble near the cradle arm which can easily be filled up. I need to find a way to avoid the bubble in the next casting.
Overall looks good enough for my dio. The front sights only has one of the guards so I'll just fashion a new sight guard from copper sheet.
So John R, the gun will be standing on it's own once I scratch the tri-pod. Thanks for the suggestion.
RichardComment
Hi Jim, I use the clear slow drying stuff 'cos I can take my time with the pour and lets all tiny bubbles to raise to the surface. I also find that details are captured and slightly more refined.
It'll be great if I can source a suitable curing time resin that doesn't bubble with reaction.
RichardComment
