Photos.
[ATTACH]308800[/ATTACH][ATTACH]308801[/ATTACH]
Above you will notice the shine from a coat of pva, just to seal the first coat and assist the following one.
[ATTACH]308802[/ATTACH][ATTACH]308803[/ATTACH]
Above is the white thicker filler around the tank, hence the clingfilm.
Now for the reeds.
[ATTACH]308805[/ATTACH]
The Tamiya tape has been removed, the pva having set over night. those smaller clumps at the front R/H side are the left overs from the trimming, having the adhesive from the brush added to .Theses will represent new growth .
[ATTACH]308806[/ATTACH][ATTACH]308808[/ATTACH][ATTACH]308809[/ATTACH]
The last 3 photos are showing the BULRUSH head.
[ATTACH]308810[/ATTACH]
By adding small amounts of PVA I can build up the stem
The last photo above the real reed is am attempt an using very thin copper wire, and using the same method.
They would take a lot longer, having to be primed as well , so my not continue, but worth a try. I pleased with the reeds, looking fwd to placing them on the dio.
Thanks for looking in, comments welcome.
John.
Now for the reeds.
John.
