I have also received the crane but unfortunately is a no go! The distance between legs are to small its 7.8cm and i need at least 9cm for the inside track and 10.5 cm for the outside! So back to square one with the crane subject! I was really hoping it would work but again my luck! Anyway I don’t give up !the search goes on , i probably need 1/72 or 1/48 kit! Shame really that no company makes big cranes on rails! If the search fails then no other option but scratch build! Thanks fellas regards Danny
Maybe you could adapt the crane legs with some putty or green stuff? Green stuff is for me the solution to everything hahaha
P.S. my bad, just saw the crane design, i though ot was the one that was posted some post ago.
P.S2 maybe you could use the verliden tank reparation crane as base as it fit on the rails and just add on top the crane that you wanted, only needing some adaptation.
Good afternoon to you all! The collection of the required items has began! The first 2 kit has arrived! Also contacted U-models because I went on there website and it seems unfinished not much to see on it ! So they were kindly have sent me a catalogue and a price list of there products! So I tought i share with you guys you might need something from them in the future! Regards Danny
So that is the catalogue I hope it helps fellas the only page that the site doesn’t allowed me to upload is the price list so if you guys need message me PM and I send it over maybe in an email!
Some very interesting models .... just need more £££ to get some.
Hi there everybody! Like I said before loads of things to collect before it starts! So here is another piece for the project and will be much more to come... well slowly unfortunately! [ATTACH]312074[/ATTACH]
Hi Gary thanks I know what you mean is difficult to find kits ! Usually I just sit for hours and search and when i see something I like ...usually its an old kit and hard to get or not in production anymore! These 3 kit I found it on ebay if you surf enough you might get lucky if you need any help to find kits let me know try my best to help you find it! Regards Danny
