Did you see them coming?
  • scottie3158
    • 14221
    • Holbeach
    #286
    The rear of the vehicle was detailed today. The moulded on canopy supports were replaced with drilled out evergreen rod.. The tie downs were added using 0.3 copper wire. Eyelets were added to the tail gate chains from the same wire. The rest was binged up with a bit of etch, wire and foil.
    I have to replace the poles this I will do tomorrow. When this is done It will be time to sort out the stowage.
    [ATTACH]327034[/ATTACH]
    [ATTACH]327035[/ATTACH]
    [ATTACH]327036[/ATTACH]
    [ATTACH]327037[/ATTACH]
    [ATTACH]327038[/ATTACH]
    all comments welcome
    Scottie
    • JR
      • May 2015
      • 18273
      #287
      Paul quite stunning.love those tensioners, did you bend that pewter ?
      John.
      • Mr Bowcat
        SMF OG
        • Dec 2016
        • 4608
        • Bob
        • London
        #288
        Not sure how I missed thread before Paul, awesome work. :thumb2:
        Si vis pacem, para bellum.
        • scottie3158
          • 14221
          • Holbeach
          #289
          John.
          Thanks John, I must admit I do like how the tensioner worked out. Do you mean the pewter on the bumper?
          • scottie3158
            • 14221
            • Holbeach
            #290
            Bob,
            No worries it is easy to miss posts on here, but glad you found it and it meets with your approval.
            • JR
              • May 2015
              • 18273
              #291
              Yes Paul.
              John.
              • scottie3158
                • 14221
                • Holbeach
                #292
                Yes Paul.
                John.
                John,
                The pewter was bent in the same way as normal etch using a folding tool. I normally use smooth pliers but that was a bit long for the jaws.
                • minitnkr
                  Charter Rabble member
                  • 7551
                  • Dayton, OH USA
                  #293
                  Oooohhhh, the details, the details! PaulE
                  • scottie3158
                    • 14221
                    • Holbeach
                    #294
                    I came up with a cunning plan, cut out a template of the load area then stick the stowage to that so I could remove it to paint it. Somewhere along the process I think I have got some glue somewhere as I can't seem to get it out now:rolling:. The cam net was added using gauze soaked in diluted PVA. This has been left to dry over night. Next will be to form a tarp which wont cover all the load but probably be mostly rolled up and draped over the 45 gallon oil drums.
                    [ATTACH]327140[/ATTACH]
                    [ATTACH]327141[/ATTACH]
                    Scottie
                    • scottie3158
                      • 14221
                      • Holbeach
                      #295
                      Hi Paul, Thanks for looking in. The good thing about this type of vehicle is you can add pretty much what you like here you like.
                      • minitnkr
                        • 7551
                        • Dayton, OH USA
                        #296
                        You betcha. Bummer on the stuck load. Looks like barrels are upside down unless you've yet to add the bungs. Your latches, catches & hooks are just outstanding. PaulE
                        • scottie3158
                          • 14221
                          • Holbeach
                          #297
                          John,
                          I haven't added to any details to the drums or filled the gaps as these will be covered with a tarp so they are there just to form the shape underneath. Glad you like the rest of the details.
                            Excellent work Paul.
                            • Steve Jones
                              • 6615
                              #299
                              Looks like it is all ready for the boys jolly to Margate now!! Just make a small space in the back to hide JR. We don't want to upset the locals:smiling5::smiling6:
                              Cracking build mate. Are you using Milliputt or foil for the tarp and will there be any of your famous eyelets??
                              • scottie3158
                                • 14221
                                • Holbeach
                                #300
                                Thanks Ralph appreciate the kind comment.
