BMP -2 In Aleppo - Buildings construction
  • Steven
    • May 2018
    • 589
    Hello all
    I am working on a diorama with a SAA BMP - 2 In outskirts of A,leppo scale is 1/35 period is not set but will likely be in the later stages of the Civil War. Discussion regarding the layout can be found Here, but in short there will be a lower building in the foreground - partly in ruins and a large apartment/ storefront complex in the background, also partly destroyed.
    BMP: will be parked and crew talking to troops on the ground, believing the area to be cleared - not so....
    [ATTACH]343603[/ATTACH]
    Materails will be a mix of foam and plaster - working in foam is a first for me.
    Lower Building:
    Is going to be a grocery store/Bodega with large opening blinded by rolling shutters - the roof will be collapsed so not much of the interior will be seen
    I have begun work on the lower building, for ease of construction, I have not glued the parts together yet , also I am planning to have the facade rendered using - hmmm- plaster of Paris I guess - any better alternatives? with parts of the brickwork showing
    The Window is thought to be a display window or a smaller opening to serve patrons.
    [ATTACH]343604[/ATTACH]
    I had to redo the sidewalk a few times but I fairly content with this:
    [ATTACH]343605[/ATTACH]
    [ATTACH]343606[/ATTACH]
  • spanner570
    • 15414
    Steven, regarding your question about alternative rendering, when I did my burned out Abrams tank diorama on here in May, I found the foam board/ polystyrene on its own was fine for the render. I just dug some bits out here and there.
    I then painted the exposed blockwork a slightly different colour to the render. Keep in mind these buildings were usually 99% concrete blocks and pillars, then rendered.
    I hope the above link will be of some help to you.
    Whatever method you adopt, just have fun when you create trashed and damaged buildings. I do!
    Ron
    • Steven
      • May 2018
      • 589
      Ron - you are quite right they do have a rendered finish on their own - I am going to play around with some trial pieces, both rendered and without to see what works best for me - thanks for the input mate :thumb2:
      • spanner570
        • 15414
        Glad to help.
        Just a couple of quick pointers which you might know already.....
        Be careful what glue you use. Some will melt the foam board. I use UHU POR, it's specially for foam board and any polystyrene.
        Before you apply any sort of 'Render', prime the board with watered down P.V.A. and let it dry.
        Cheers.
        Ron
        • Steven
          • May 2018
          • 589
          Thanks for the tips :-)
          • Steven
            • May 2018
            • 589
            trial - wall rendered - I am pretty happy with this first attempt - I am just playing around atm :smiling:
            • spanner570
              • 15414
              Trial? Playing around? That looks excellent Steven!........:thumb2:
              Who needs to add any extra stuck on render?
              Ron
              • minitnkr
                Charter Rabble member
                • 7541
                • Dayton, OH USA
                A great "trial". Very well done. PaulE
                  All good fun:smiling4:.
                  • Steven
                    • May 2018
                    • 589
                    thanks guys:smiling:
                    • Steven
                      • May 2018
                      • 589
                      Rendering the left building is having a sanding and the right is not sanded [ATTACH]321993[/ATTACH]
                      • spanner570
                        • 15414
                        Is that polyfilla or similar I see applied?......:surprised:
                        • JR
                          • May 2015
                          • 18273
                          Steven.
                          Ron is quite right in his thoughts on the board.
                          I use a plaster board adhesive for the skim over the foam ( only because I had a tub left over ). Looking at yours its seems perfect what ever you have used. The finer the mix the easier to sand, poly filler, plaster , they are all pretty much the same.
                          Looking fwd to more photos.
                          John.
                          • Steven
                            • May 2018
                            • 589
                            It is :smiling4:
                            Steven.
                            John.
                            You are so right, I chose Pollyfilla for the fine grain it has thinking it would yield a nice finish and it is not shabby I guess
                            • Steven
                              • May 2018
                              • 589
                              Whilest working on the facade of the building i have been playing around with the collapsed roof it is aboutn1.5 cm in thickness and i use 0.1 og mm wire and have a hard time getting thw right sizing for the rebar i spotted some at a construction site meant for flooring and they were about the size of my inedex finger
