BMP -2 In Aleppo - Buildings construction
  • rtfoe
    • 9094
    #196
    Clever. :thumb2:
    • Steven
      • May 2018
      • 589
      #197
      Thanks gents
      Remembet the improvised mortar? I am planning to build a protective barrier around the position and have toyed with the idea of having it consist of piles of some sandbags on top , rubble and oil drums filled with sand/ rubble they face inwards on the pic's but i have yet to decide which way they will face ,- iam leaning towards having them face the viewer as they add a bit of interest to the edge of the dio
      [ATTACH alt="20191110_152036.jpg"]363121[/ATTACH][ATTACH alt="20191110_192854.jpg"]363124[/ATTACH]
      • JR
        • May 2015
        • 18273
        #198
        Hi Steven, just had a catch up, wow is the word.
        Love everything, the inside of the shop looking back at the shutter, fantastic, very realistic, the walls and the posters !
        Top rate work ,loving it :thumb2::thumb2::thumb2::thumb2::thumb2:
        Rubble & Debri R Us
        • Steven
          • May 2018
          • 589
          #199
          Barrels facing outwards
          - Construction of the barrier temporarily halted as I ran out of UHO por
          • JR
            • May 2015
            • 18273
            #200
            Nice, pity about running out of POR
            • Steven
              • May 2018
              • 589
              #201
              True
              Little more work done
              Will make it more interesting by adding debris of war like an ammo box etc on it and ah, also sandbags ...
              On the right hand side it will merge into the rubble piles of the building
              • minitnkr
                Charter Rabble member
                • 7550
                • Dayton, OH USA
                #202
                Some excellent work. PaulE
                • Neil Merryweather
                  • Dec 2018
                  • 5199
                  • London
                  #203
                  brilliant!
                  • Steven
                    • May 2018
                    • 589
                    #204
                    Thanks gents
                    Sandbags underway i am going to do 4 layers maybe with firing slots build in by integrating ammo boxes
                    Also made the end on the LH side taper a bit more naturally
                    • JR
                      • May 2015
                      • 18273
                      #205
                      Steven as a fellow rubble builder I have to congratulate you on the texture, very realistic. Notes taken !
                      • Steven
                        • May 2018
                        • 589
                        #206
                        Thanks John i live in an old building where the rendering is flaking and brick and mortar have seen better days so i collect what i need and sift it through various sieve to get varying degrees of corseness.complete with cat litter and bits and pieces of what is lying around that might look good - you can always cover it up
                        • Steven
                          • May 2018
                          • 589
                          #207
                          I think in terms of adding texture the mixing in of gravel and small pebbles in the plaster/celluclay or what is etc is very important
                          • JR
                            • May 2015
                            • 18273
                            #208
                            I agree Steven, I recently made up some wall filler, made 3 lots, adding colour to each . Spread thinly and allowed to firm up, then cut some straight lines into the mixes and did some small brick shapes.
                            When dry I bagged then up, as I used some on the Tiger dio I ground some up into very small pieces, certainly gives the desired look. So thank you for posting those photos .
                            • Steven
                              • May 2018
                              • 589
                              #209
                              Good idea mr. Race :smiling:
                              Some ammo boxes for said firing slot :
                              • JR
                                • May 2015
                                • 18273
                                #210
                                Like the wear on those boxes, very realistic Steven .:thumb2:
