A little of what you Fantasy
  • wotan
    • May 2018
    • 1150
    I have always had a side interest in Fantasy figures since they allow ultimate artistic license and no accuracy pressure. So keeping up with my interest in painting 28mm figures I decided to have a go at a little fantasy diorama. There was also a little influence from the Scottish falling over juice, which never goes amiss, as you will see.
    The object is to build a little bit of a castle and a sort of adventurers scene. Started off with some convenient packaging.
    [ATTACH]327824[/ATTACH]
    Now this needs to be textured so I found some very convenient peel and stick cork. Probably meant as some sort of shelf liner, but equally useable for stones.
    [ATTACH]327825[/ATTACH]
    First couple of courses laid and the beginings of some ground work using insulating foam.
    cont/.....
  • wotan
    • May 2018
    • 1150
    More brick laying.
    [ATTACH]327826[/ATTACH]
    Now I am thinking that I will probably want to add lighting to this as well so the top of the tower will be left loose to get to the electricals.
    Just about finished the brick work and I have added a little filler using Hydrocal, which is a sort of light weight plaster of Paris.
    [ATTACH]327827[/ATTACH]
    [ATTACH]327828[/ATTACH]
    The next step was to add some architectural details using Magic Sculpt. Now I am completely making this up as I go along so there is no real reason for any of the details.
    [ATTACH]327829[/ATTACH]
    I have added a stairway to the entrance using insulating foam and Hydrocal. I am now shopping for the figures that will inhabit this little scene. Plenty to pick from so watch this space.
    • rtfoe
      • 9086
      John,
      Great idea on using the cork for lining the curved walls...definitely using it in future. Like what you sculpted on each side of the window...are they gargoyles?
        Nice work
          • 22770
          Nice start John love the Owl window gargoyles.
          • Si Benson
            • 3572
            Morning John,
            Nice building...look excellent even before painting :thumb2:
              • 18908
              Really nice.....love the cork and magic sculpt effect.....
              Where did you source the peel and stick cork?
                I love those kind of works!!!
                  • 15707
                  Hi John
                  Loving it. Great idea to use the cork.
                  • scottie3158
                    • 14202
                    • Holbeach
                    Hi John,
                    A very neat idea will follow along and see what magic you weave.
                    • wotan
                      • May 2018
                      • 1150
                      Gents welcome along and thank you for taking the time to add your likes and your comments.
                      I think the gargoyle thingies are indeed Owls although no idea why. I will simply try to add in as many fantasy cliches as I can think of.
                      Meantime I have been shopping for some figures. I never knew there were so many Skryves, sorcerers, druids, skull cleavers, thieves, bards, Stykers etc etc. I picked out a few of the slightly less bizarre models so now I await the postman.
                      Continuing with a little more detail I have made up the front door. Made from scribed plasticard and painted with drawing inks.
                      [ATTACH]327884[/ATTACH]
                      It will be tucked away so should look OK. I also added a gallery to the first floor window and the little bridge to get to the front door.
                      [ATTACH]327885[/ATTACH]
                      [ATTACH]327886[/ATTACH]
                      Having fun trying to imagine where to put the trap doors, treasure chests, beast lairs etc
                      • dave
                        • Nov 2012
                        • 1828
                        • Brussels
                        Looks good, if you need a second tower, I am willing to volunteer to help you empty the Laphroaig first.
                        • Peter Gillson
                          • 2594
                          Great to see something different.
                          Great build so far, you have acheived a lot of great details. One thing to remember is to ensure the pattern of the stone block on the inside of the castilations matches the outside.
                          Have you seen this French castle reconstruction? Thought it may be of general interest: https://www.guedelon.fr/
                          Peter
                          • Si Benson
                            • 3572
                            Your a good man Dave...always ready to help out:smiling5:
                              Looking really good so far!!
