A little of what you Fantasy
  • Andy Belsey
    • 887
    #91
    Great work John! I love the vibrancy of this. And nothing's stolen. We share techniques to inspire and help each other. That's why I'm here anyway!
    Andy
    • minitnkr
      Charter Rabble member
      • 7551
      • Dayton, OH USA
      #92
      The colors, the details, the whimsy, the action, you've got it all going here John. Outstanding. Savage Mouse reminds me of Wee Forest Folk sculpts. PaulE
      • Mickc1440
        • 4779
        #93
        This is stunning work John
        • Peter Gillson
          • 2594
          #94
          The trees fits in really well, a nice composition.
            John,
            Only one word - Yes!
            Mike.
            • wotan
              • May 2018
              • 1150
              #96
              Your kind comments are really appreciated and I am having lots of fun playing with new techniques etc etc.
              I know some of you are already expert at this but for me casting has always been a dark art. Having looked at a number of fantasy based sites I saw that casting paving floors, walls etc etc was very common. So although I don't know what I am going to do with this yet I thought I would give it a go, and provide a simple SBS for anyone who wants to try the same experiments. I decided to try to cast a section of rough stone wall.
              Step one involved cutting a 1cm thick sheet of insulation foam, and then cutting it into rough stone shaped blocks. I sanded off the edges to give a worn look and stuck them together with white glue to form a basic wall. I then took a sharp knife and cut this in half along the long axis and stuck both halves to a piece of firm card, Step 2. This was given a coat of acrylic sealer and a thin coat of Gesso just to protect it.
Name:	casting 1 2.jpg
              I found some quick set silicone mould making putty in my local art store, Photo 4 shows the stuff I found. This comes in two parts, and like miliput etc you simply mix the two putties together to form the quick set moulding stuff. I smothered my rough wall with this mixture. Now this stuff takes about 10 minutes to set so you need to work fast.
Name:	casting 3 4.jpg
              After 10 minutes I peeled the mould off the original and voila! a rubbery mould ready to go. Step 5. I then made two casts from this mould the first in Hydrocal (like plaster of paris) and the second in quick set resin mix.
Name:	casting 5 6.jpg
              I think the result is very acceptable in both cases. The hydrocal version is probably cheaper to make than the two part resin mix.
              I intend to continue casting these sections then to create some kind of house or castle etc by simply sticking them together maybe on a light cardboard backing. Notice that with the form I have made they fit together top to bottom, end to end and you can turn each casting in any direction so that the finished wall does not appear too repetetive.
              I hope this is useful to someone.
              • scottie3158
                • 14220
                • Holbeach
                #97
                John,
                very simple but effective.
                  Very fine work John, and becoming a mega-production!
                    • 22771
                    #99
                    Just caught up John, some very impressive work so far.
                    • rtfoe
                      • 9100
                      #100
                      Vibrant it is John needed shades for the bus. You've put some of the real gardeners to shame with your instant garden. Nice production line on your stone casting.
                      • wotan
                        • May 2018
                        • 1150
                        #101
                        Thanks one and all.
                        Been getting carried away with casting building components. I think I have nearly every thing for at least the first storey,
Name:	house components.jpg
                        Fun Fun Fun
                          John...you are showing how many work there is behind a diorama. A magnificent diorama!
                          Excellent build so far.
                          • wotan
                            • May 2018
                            • 1150
                            #103
                            Thanks for hanging in there Polux
                            First floor built and primed. Very happy how this came out, and learned lots about casting buildings along the way.
Name:	Inn RC 1.jpg
Name:	Inn RC 2.jpg
                            This is another Fantasy Cliche..... The Inn....
                            • JR
                              • May 2015
                              • 18273
                              #104
                              Wow from here, Mrs R complemented you on the garden said it looked real, :nerd::thumb2::thumb2::thumb2: praise indeed John .
                              Thanks for the SBS, you make it look so easy !
                              The other John .
                                [ATTACH]329709[/ATTACH]
                                [ATTACH]329710[/ATTACH]
                                [ATTACH]329711[/ATTACH]
                                John,
                                One word of advice, if you are going to do multiple castings then use a release agent, it can be a brush on or a spray can, I prefer to brush as more control. But once you have worked your magic on the walls i am sure they will fit in. Mike.
