KV 1 meets a little Panzer.
  • JR
    • May 2015
    • 18273
    First thing after finding a section of 18 mm was the gluing of the foam.
    I've not used this foam before, It was a section of insulation that my son in law gave me has been under the work top for some time.
    I used UHU POR to glue it down, moving the foam around to push any trapped air out, this gives a better grip then I left it over night with some weights on top.
    The next morning, with the weights removed a good coating of a PVA bonding adhesive was applied.
    I used this at work so still had it in stock, waste not want not. :smiling3::smiling3:. Other makes are available
    I gave the whole area a good coating and left it to dry for a couple of days.
    When fully dry I used the old Drywall adhesive, had it since the cave refurbishment , so its well over a year old, been kept under the worktop and has never be allowed to freeze.
    When dry it looked like this, now having placed the panzer in place before hand there was some digging to achieve the correct sunk into the water look .
    Too flat.... so .......
    Much chopping out and drilling, followed by even more sealing.
    Once that was done several coats of cheap acrylic paints were used to make a start to the dio look .
    Now there will be ruts in that road, so some more filler will be applied, I used at the rear a mix of PVA, the same as the sealer coat but just added some wall filler to build that area up, will used the same on thew road.
    Once the the tanks are ready, along with the figures they will be glued in position then the ice and snow can start. Oh happy days indeed.
    Right off for some late tea.
    comments welcome.
    John.
    Great work John. A really ambitious set up.
    • Mini Me
      • Jun 2018
      • 10711
      JR, I see you are happily at it again with the ice and snow. Playing with all that cold stuff would make me want a cupper as well
      Cheers Mate, Rick H.
      • JR
        • May 2015
        • 18273
        Morning Peter, thank you. I can see it in my mind, just have to not rush it !
        Hi Rick, yes love it, bit different from fire , two poles apart .
        Loads to do, will keep me busy for a good while yet .
        Thanks for your comments.
        John .
          • 15728
          Hi John
          That looks very good. Well planned out. Good use of available material.
          • Lee Drennen
            • 7711
            Nice work so for John! At least I donโ€™t see and burn marks yet
            • grumpa
              • Jan 2015
              • 6142
              Coming along nicely, a real landscaper you are.:thumb2:
              Jim.
              • Steve Jones
                • 6615
                Ah! The easy bit - building a base :smiling5:
                Rather you than me mate. Looking forward to seeing how you tackle the broken ice. Good luck mate
                • Fernando N
                  • 2448
                  Great start at the base John:thumb2:, this will be interesting with the ice and snow involved.:smiling:
                  • scottie3158
                    • 14211
                    • Holbeach
                    John,
                    Something tells me I am looking in on another great build.
                    • JR
                      • May 2015
                      • 18273
                      Originally posted by Jim R
                      Hi John
                      Thanks Jim.
                      No Lee apart from Ice burn there won't be any.:smiling2::smiling2:
                      Jim.
                      Thank you Jim, a nice comment esp as the next is from Steve. :smiling3::smiling3::smiling3::nerd:.
                      :flushed::smiling::smiling3::smiling5::tongue-out3: as for the Ice I had a look this afternoon and put It straight back in its packaging:surprised::thinking:.
                      Thanks mate, feel I have to do the whole thing, like the grass in an winter setting before I tackle this ice part.
                      John,
                      Very kind of you to say Paul, I do feel that some care will be needed to get this just right.
                      John.
                      Having given the base several layers of filler, and paint, I decided to make up some soil as I had said earlier. I needed to blend the colours in and put the reeds in while I did this, so mixing some acrylic paints in with some thick PVA I set too .Drilling out the holes for the reed steams resulted in a lot of white areas around the holes, with the end of the reeds dipped in the thick brown gungue it soon looked right. Another thick coat of varnish from W/N was used to help seal the base.At this point I realised it was an oil based varnish so I hope it will be ok over the other acrylic coats. Once dried I may give it another thin coat of the satin acrylic, any pointers on this would be appreciated.
                      While this was settling I popped it some roots again using the thick coloured pva. I've put some autumn glass in , didn't use the magic grass thingy as can't find the grease proof paper to make the tuffs. Added some roots for the trees and put down some pva along with a scattering of 4mm autumn grasses. They would have been flattened by now so no worries with not having them all standing up.
ID:	1087492Click image for larger version
ID:	1087493Click image for larger version
ID:	1087494Click image for larger version
                      Pleased with this so far, had a look at the ice earlier and put it back in its packaging quickly, going to have a look look at their site before I attempt the ice part.
                      Thanks for following .
                      John.
                      • Si Benson
                        • 3572
                        Looking very nice so far mate :thumb2:
                          Looking very good John. A very convincing bit of landscaping.
                            • 15728
                            Great work John. Looks realistic.
                            • spanner570
                              • 15427
                              453 - Not bad, not bad at all........ :thumb2:
                              570
