supermarie spitfire dio
    hello everybody hints and tips on the build off the plane would be great ta and here are some pics off the diorama ...steve [ATTACH]35081.vB[/ATTACH][ATTACH]35082.vB[/ATTACH][ATTACH]35083.vB[/ATTACH][ATTACH]35084.vB[/ATTACH][ATTACH]35085.vB[/ATTACH][ATTACH]35086.vB[/ATTACH][ATTACH]35087.vB[/ATTACH][ATTACH]35088.vB[/ATTACH][ATTACH]35089.vB[/ATTACH][ATTACH]35090.vB[/ATTACH][ATTACH]35091.vB[/ATTACH][ATTACH]35092.vB[/ATTACH]
    and i have tryed spary snow as you can see its not any good any tips plz ..steve
    [ATTACH]39555.IPB[/ATTACH]
    [ATTACH]39556.IPB[/ATTACH]
    [ATTACH]39557.IPB[/ATTACH]
    [ATTACH]39558.IPB[/ATTACH]
    [ATTACH]39559.IPB[/ATTACH]
    [ATTACH]39560.IPB[/ATTACH]
    [ATTACH]39561.IPB[/ATTACH]
    [ATTACH]39562.IPB[/ATTACH]
    [ATTACH]39563.IPB[/ATTACH]
    [ATTACH]39564.IPB[/ATTACH]
    [ATTACH]39565.IPB[/ATTACH]
    [ATTACH]39566.IPB[/ATTACH]
    • 18269
    As far as tips for the aircraft build part, there were several people on here that all build that kit at the same time. It is quite an amusing set of posts....
    The pen looks good to me. As far as spraying snow goes, I think that there are other more prolific dio builders on here to help with that one. I would probably go the baking powder side of the fence.
    • stona
      • Jul 2008
      • 9889
      Hi there,that's a challenging kit. Several of us did indeed build them as a sort of unofficial group masochism session! Here's my build thread if you want a laugh. Plenty of advice from the other masochists in there too.
      http://www.scale-models.co.uk/under-construction/11707-yet-another-spitfire.html
      The biggest single issue that I think we all had is the twisted nose,I can see it in your second photo. You need to figure out a way of straightening that enough to make the cowling panels fit. I did a sort of compromise bodge. I also never got the fin vertical,there is a sort of gentle twist about my whole model but it looks okay if you look too closely.
      I cheated and posed mine in flight!
      • colin m
        • 8750
        • Colin
        • Stafford, UK
        Oh wow, I remember this one. If you search the forum, I think there was about 4 or maybe 5 being built at the same time. We all frequently discussed the latest problem we had just found. But, at the end of the day it can be built into a nice looking model. Stick with it, it will turn out alright.
        Steve's little cheat was to pose his in flight. My little cheat was to pose mine with the engine on display, hence no need to worry about the twisted nose !
        Good luck,
        Colin M........
          thanks ian m...and stona one problem i want the engine showing grr ... i think am going too flow this model me and putty dont get a long as seeing yours god think i need to think off my options
            • 18269
            In all fairness the builds that where done all came out rather well. Just go slowly at it and dry fit everything!
            • spanner570
              • 15402
              Steve, try this for your snow.....
              Get a plant spray, set it to mist and lightly spray where you want the snow (Don't over do it) Then get some white polyfilla powder in a sieve and hold over the damp area. then gently tap the sides of the sieve. Hey presto, snow. The harder you tap the thicker the snow!...Sorted.
              Ron
                thanks every body i want this done as my next model it a german seaplane cant wait to start tht one cheers steve
                  Best of luck mate, it's a bugger to get things to fit but I'm quite happy with mine. Just needs patience and the ability to put it down, go for a fag, beer, drive, scream into a pillow, etc. and then go back to it.
                    Delmonteman. Thanks for that cant wait to start lol
                    • stona
                      • Jul 2008
                      • 9889
                      Probably a good idea to put the cat out......then you can't kick the poor sod!
                        Lol i think ive have brought the wrong kit is the kit that bad
                          The only real troubles I had was the joining of fuselage to wing and that the nose was a bit warped. I was still more than happy with the price I paid for it. Fairly certain I invented at least three new swear words while building too!
                            Lol well going to start the on the plane today i will take pic and update everybody later . Does any one know where i can get oil drums in 1.32 or 1.35. and what else could i put around this diorama cheers steve
                            • stona
                              • Jul 2008
                              • 9889
                              Some suggestions,but know idea where to find them,most can be easily scratch built. Tarpaulin covers/heaters,wing walk ladders and chocks.
                              Or here,on Malta,less formal chocks a.k.a.rocks! BTW notice the four canonn armament.
                              A trolley accumulator and some ammunition boxes.
                              And,if all else fails,a dog. Sgt Hyde's dog pictured here was called Dingo. Hyde was from Trinidad but Dingo doesn't look like an Aussie to me!
                              One thing surprisingly rare to see,except around accidents,is fire extinguishers. I've no idea why. This is obviously a Hurricane rather than a Spitfire but they were taking no chances.
