Thank you gentlemen. Some progress. Civilian OA set-up in insp. pit.
45 Red oxide primer armor & late 44 green bogies. What about camo? Your thoughts.
C&Cs encouraged. PaulE
If very late war. Just splash on a little dunkelgelb in random almost careless strokes to produce that last ditch effort at getting it done and into action. I really like the progress on the rest of the dio. Keep the mojo flowing. Rick H.:thumb2:
Thanks, me too. I can't seem to locate my 9v reclaimed battery holders & connectors. Haven't seen them since the cave remodel. I must have put them in a 'safe' place. PaulE
Cut up the tuckered out smoke alarm for the battery connector & holder & tested result. Front view. Some light bleed evident. Will add foil between bulbs & roof.
Rear view.
Left side view.
Now to finish up crane & vehicles/carbon units. C&Cs encouraged. PaulE
Thanks Dzohn, couldn't use the cool little lamps, had to use some spare HO loco headlight bulbs as the 1.5v batteries were too dim & the 9v battery was too bright. PaulE
Paul that light out put looks right, if you had used those small lights it would have looked insipid, and the bigger out of scale. Once you get those light bleed filled ( don't they just annoy you when you've done all that work) I hope you will post some again.
Dzhon.
