revell 1.32 Arado Ar 196A-3 seaplane dio
    and i have orded from hannants today
    [ATTACH]36719.vB[/ATTACH][ATTACH]36720.vB[/ATTACH][ATTACH]36721.vB[/ATTACH][ATTACH]36722.vB[/ATTACH]
    [ATTACH]40954.IPB[/ATTACH]
    [ATTACH]40955.IPB[/ATTACH]
    [ATTACH]40956.IPB[/ATTACH]
    [ATTACH]40957.IPB[/ATTACH]
      All the things for this diorama is 1.35 scale but the plane is 1.32 is it going to. Look right? Cheers steven
        • 18271
        Well I think that you will not be the first to put 1/32 aircraft together with 1/35 figures and cars.
        It should be fine if you ask me.
        Whilst one the subject, if you take say a 1/48 scale pilot from Tamiya and sit it next to a 1/48 scale figure from Airfix the difference is obvious and they are supposed to be the same scale. The same can be said of some aircraft kits.
        I would go for it and see how it looked before every thing gets bolted down.
          Ian u said somethink about AA stations what do u mean cheers steven
            Stephen pretty sure he means anti aircraft gun emplacements
              you sure ?
                does any one know if i can use Schimmwagen to tow my seaplane out ???? and i just hope that i can fit all this on cheers steven
                  • 18271
                  AA stations. Yes I meant emplacements but it's easier to spell!!!
                  I dont think that the Schwimmvagen would have the tork to pull the Ardo on the flat let alone up a ramp. I could be wrong but I just cant see it.
                  25 horse power. 4wd only in first and reverse gears(in some models) and a total weight of 900kg........Then there is the problem that they did not have a tow hitch of any kind as that would of gotten in the way of the fold down propeller for water running.
                  Sorry.
                    what about this to tow the plane ?
                    [ATTACH]36759.vB[/ATTACH]
                    [ATTACH]40994.IPB[/ATTACH]
                      well the truck at the back cheers steven
                        [ATTACH]36815.vB[/ATTACH][ATTACH]36816.vB[/ATTACH][ATTACH]36817.vB[/ATTACH]
                        [ATTACH]41043.IPB[/ATTACH]
                        [ATTACH]41044.IPB[/ATTACH]
                        [ATTACH]41045.IPB[/ATTACH]
                          [ATTACH]36818.vB[/ATTACH][ATTACH]36819.vB[/ATTACH][ATTACH]36820.vB[/ATTACH][ATTACH]36821.vB[/ATTACH]
                          [ATTACH]41046.IPB[/ATTACH]
                          [ATTACH]41047.IPB[/ATTACH]
                          [ATTACH]41048.IPB[/ATTACH]
                          [ATTACH]41049.IPB[/ATTACH]
                            [ATTACH]36822.vB[/ATTACH][ATTACH]36823.vB[/ATTACH][ATTACH]36824.vB[/ATTACH][ATTACH]36825.vB[/ATTACH]
                            [ATTACH]41050.IPB[/ATTACH]
                            [ATTACH]41051.IPB[/ATTACH]
                            [ATTACH]41052.IPB[/ATTACH]
                            [ATTACH]41053.IPB[/ATTACH]
                              [ATTACH]36826.vB[/ATTACH][ATTACH]36827.vB[/ATTACH]
                              [ATTACH]41054.IPB[/ATTACH]
                              [ATTACH]41055.IPB[/ATTACH]
                                [ATTACH]36830.vB[/ATTACH][ATTACH]36831.vB[/ATTACH][ATTACH]36829.vB[/ATTACH][ATTACH]36828.vB[/ATTACH]
                                [ATTACH]41056.IPB[/ATTACH]
                                [ATTACH]41057.IPB[/ATTACH]
                                [ATTACH]41058.IPB[/ATTACH]
                                [ATTACH]41059.IPB[/ATTACH]
