T 38 Amphibious Tank 1/35 scale by PARC models.
  • JR
    • May 2015
    • 18273
    #106
    453.
    I've been away for 5 days on a cheapo with a certain Irish Airline and just plugged in!
    Nice work thus far old lad.
    Re loading pictures. I found out this morning my Hurricane thread photos were gone. I didn't have any trouble re- loading them. I used 640 x 480 size.
    Good to be back with the boys and girls.
    570
    Greeting 570 , and here we were thinking you'd been sectioned !
    Yours 453.
    • JR
      • May 2015
      • 18273
      #107
      Success tonight.
      • JR
        • May 2015
        • 18273
        #108
        This was the state of play tonight.
        More filler added plus some pva into the mix along with some colours
        The difference in the front is due to light from above
        John .
          Excellent John - how not to give up. Inspiring.
            • 15681
            Hi John
            Looking good. Well done to you for keeping at it.
            • Mini Me
              • Jun 2018
              • 10711
              #111
              Keep 'er going mate. Rick H.
              • JR
                • May 2015
                • 18273
                #112
                Thanks, beging to think my middle name should be " determined " :smiling3:.
                Originally posted by Jim R
                Hi John
                Cheers Jim.
                Cheers Rick .
                John .
                Quick up date, thought as I'd added the pva to the last mix all would be sealed ! Er, slight error !:flushed: made a mix up of Precision Ice and Snow water did a pour.
                Seemed alright for about and hr then appeared as if the tank was trapped in a sea of mud. Luckily I had taken the precaution of setting the whole thing on a plastic sheet on paper, as it was in the kitchen drying. !!! :surprised: All was not lost, but suspect this morning will give a true picture of what's what.
                Why I hadn't done as in the past a couple of good sealing coats to the base is somewhat annoying as it's a basic task when doing any diorama with water.
                Assuming that when this first pour is fully cured in 48 hrs I can do another and finish.
                I'd wanted to run a toothpick through the water mix as it dried to give a impression of movement, this doesn't seem to work even on the pooled areas I'd managed to retain. Back to the use of a Gel later I feel .
                John .
                • JR
                  • May 2015
                  • 18273
                  #113
                  Just come into the drying area ( kitchen ) not as bad as expected think as it's dried it's sealed
                  The one thing I do like us the " water on the front, sort of bow wave and in the track guards .
                  Still a little soft on the surface so will leave for the rest of the week.
                  Don't know if to add a coat of acrylic varnish to the top then another pour. Any ideas, both the resin and varnish are water based .
                  John .
                    • 15681
                    Hi John
                    That actually looks very good indeed. Once it is all sealed you should have no more trouble.
                    Maybe I'm wrong but isn't that Precision Ice and Snow water a rubbery silicon sort of stuff so may not take acrylic varnish. As I say though I am not sure.
                    • JR
                      • May 2015
                      • 18273
                      #115
                      Hi John
                      Thanks Jim, well on that score I don't know, I'll drop them an email I think .
                      John.
                      email sent Jim , so will report back .
                      • SimonT
                        • 2824
                        #116
                        Hi John,
                        You can pour another layer of PI&S water over the first without any prep with no problem
                        Haven’t tried painting it so can’t help there
                        It does tint nicely with a little dry pigment powder
                        • Lee Drennen
                          • 7711
                          #117
                          Looking good John better each time like the different angle shots
                          • minitnkr
                            Charter Rabble member
                            • 7529
                            • Dayton, OH USA
                            #118
                            Now that you've conquered Earth, Fire & Water, what's next? You're casting a large shadow Mr. Determined. :smiling4: PaulE
                            • Steve Jones
                              • 6615
                              #119
                              Your determination to become a creator of land and water is way beyond my meagre talents. I shall just look on in awe and hope and pray it comes out the way you want it to
                              • JR
                                • May 2015
                                • 18273
                                #120
                                Originally posted by SimonT
                                Hi John,
                                Hi Simon, thanks, the varnish was just to seal, not heard back from them yet. I've used the one with bit of stick in and a muddy tinge, but of course you can't see that with all the colour under it :smiling3:.
                                Thanks Lee.
                                :smiling3::smiling3::smiling3: cheers Paul, had to smile at that one buddy. Just more I hope.
                                Your too kind Steve thank you. Struggle at times with the plastic, but looking at this I struggle with the dios as well ! :smiling::smiling:
                                Onward dear friends .
                                Thanks for looking in.
                                John.
