Saipan. June 1944 - 75 years later......
  • spanner570
    • 15475
    I need a quick diversion from Pete's G.B and that awful brush!
    I've been wanting to have a crack at this for quite some time. So this afternoon I made a start on what I would call a 'vinegarett'.
    After the Battle for Saipan in 1944, armour and vehicles littered the beaches and the shallows.
    This will be one of them - I hope!
    I found this built 1/72 Sherman tank in a drawer. Not quite what I wanted as I would have liked the cast hull, not the welded.
    First job, a coat of rust.
    Then by sheer luck I came across a second and already built 1/72 Sherman hiding in another drawer. Cast hull, opening hatches - and an engine. Bingo! The above went back in its dark drawer.
    Here is the cast hull version.
    I made a start by sprinkling the PVA polystyrene base with sand.
    I embedded the tank (which like the above I'd brush painted with Vallejo Model Air 'Rust') into the base using silicone.
    I then tipped a load of barnacles (More sand) onto it. Then sprinkled some filler powder over the turret where I don't want the surface too rough.
    Once this all hardens I will add some colour.
    A nice little bit of therapy..... :thumb2:
    Cheers.
    Ron
  • Neil Merryweather
    • Dec 2018
    • 5205
    • London
    you really crack them out, don't you Ron?
    • scottie3158
      • 14242
      • Holbeach
      Ron,
      I really like where you get your ideas from. Doing builds like this never even occur to me.
      • spanner570
        • 15475
        Neil - don't forget, the tanks were ready made. To get to this stage only took an hour. Sprinkle sprinkle! I should also write that being retired kind'a helps too..... :thumb2:
        Paul - I've had it in my mind for some time, I'm doing the build now to calm down from 'That Brush'
        Cheers boys.
        Ron
          A snow scene in Saipan.I think you are losing the plot:tongue-out3:.Looking forward to more of this Ron.
          • spanner570
            • 15475
            Climate Change
            • Gern
              • 9250
              Climate Change
              I keep tellin' folks you got a plaster for everything!
              • Mickc1440
                • 4786
                Just checked and there is no recognised phobia when it comes to a brush Ron. Another great idea, i'll get the sun tan lotion and sit on the beach with this one.
                  • 15786
                  Hi Ron
                  What would you do without sand - rust, barnacles etc. Looking good.
                    • 22788
                    Nice start Ron I did one of these some time ago.
                    • spanner570
                      • 15475
                      Thanks for the most excellent and humorous comments chaps. Much appreciated... :thumb2:
                      The snow has melted and everything has dried out nicely overnight so I've started brushing on some marine life. For this kind of application I use cheap acrylics not my 'good stuff'
                      I've also turned the turret slightly to add a bit more interest.
                      Thanks for looking.
                      Ron
                        Looks super Ron :smiling3:.
                          • 22788
                          Coming along nicely Ron
                          • spanner570
                            • 15475
                            Thanks for sticking with it boys.... :thumb2:
                            I've added a bit of tropical colour to the sand.
                            Next some 'water'
                            Cheers.
                            Ron
                              Nice colour Ron :smiling3:.
