Rickety Bridge
  • scottie3158
    • 14201
    • Holbeach
    #16
    Originally posted by Jim R
    Hi Scottie
    That looks very nice indeed. Looking forward to the next steps. What glue do you use for wood?
    Hi Jim, I just use normal PVA or a bit of superglue on small contact areas.
    Originally posted by Pete Low
    Hi Paul, great work on the bridge it doesn't look very rickety to me. I suspect you have a cunning plan :tongue-out2:. Will keep a eye on this one.
    Pete.
    Pete, I have a plan but I wouldn't call it cunning more seat of the pants.
    Originally posted by minitnkr
    Does indeed look like German engineer work. A fine job. Sometimes a Sharpie does fine for nails/screws. They just need a touch of red/brown rust streak on verticals if older. PaulE
    Thanks Paul, that's a good point about the rusty bolts/nails.
    Originally posted by grumpa
    Nice bridge Paul, would you rebuild our bridge?
    Cheers, Jim
    [ATTACH]341558[/ATTACH]
    No worries mate if I have any balsa left over I will have a look.
    Originally posted by Mickc1440
    Nice bit of miniature woodworking Scottie.
    Thanks Mick.
    • scottie3158
      • 14201
      • Holbeach
      #17
      The work continues on the base. The basic shape has been formed from foam blocks. This has then been coated with PVA and filler. When it had dried it got a dusting of mixed grasses. Then this was dusted with Tamyia flat earth to tone down the brightness of the grass. The strip you can see will hopefully represent a concrete plinth.
      Next it is time to work on the vegetation.
      Then the bridge received a base coat of dark drown ready for the next stages.
      cheers
      Scottie
      • Lee Drennen
        • 7711
        #18
        Paul
        Your dios always look the part
        • boatman
          • Nov 2018
          • 14475
          • christopher
          • NORFOLK UK
          #19
          THE bridge looks ok to me Scottie very nice build im followin your build as like the other guys say great work :thumb2::thumb2::thumb2::thumb2::thumb2::thumb2::t humb2::thumb2::thumb2::thumb2::thumb2:
          chris
            Another superb base taking shape. Inspiring.
              • 15696
              Hi Scottie
              That don't half look good :thumb2: :thumb2: :thumb2: :thumb2:
              • Neil Merryweather
                • Dec 2018
                • 5188
                • London
                #22
                that's excellent- did you use a static machine for the grass?
                • scottie3158
                  • 14201
                  • Holbeach
                  #23
                  Paul
                  Thanks Lee glad your looking in.
                  chris
                  Thanks Chris not quite the level of detail of your build but trying.
                  Thanks Peter very nice of you to say.
                  • scottie3158
                    • 14201
                    • Holbeach
                    #24
                    Hi Scottie
                    Thanks Jim hopefully it will get better.
                    Neil, Yes mate it's a homemade affair so can be a bit hit and miss sometimes.
                    • Richard48
                      • 1896
                      • Richard
                      • Clacton on Sea
                      #25
                      I was blown away when i saw this build.Stunning bridge Paul.Admire your skills doing this.
                      Amazing fella.
                        Great groundwork :smiling3:.
                        • scottie3158
                          • 14201
                          • Holbeach
                          #27
                          Amazing fella.
                          Wow thanks Richard you are to kind.
                          Hi Ralph, Thanks mate lots to add yet so hopefully you will look in.
                          • Steve Jones
                            • 6615
                            #28
                            Terrific response from everyone Paul and rightly so. Your dio's are just as good as your models. One part of modelling I failed miserably at. Keep up the great work my friend. Will the river bed be a dry one or a wet one?
                            • scottie3158
                              • 14201
                              • Holbeach
                              #29
                              Steve, Thanks mate glad you like it so far, I should take longer on them but I tend to rush them a little. I hoping to have a shallow stream running under the bridge, this again is a new adventure as I have only ever done puddles before so it could all go horribly wrong.
                              • scottie3158
                                • 14201
                                • Holbeach
                                #30
                                I have put some colour on the bridge with various browns in preparation for weathering and detailing.
                                Had a go at a tree. I want you to be brutally honest, how do you think it looks. I still have work to do on it but as to the basic form yah or nah.
                                cheers
                                Scottie
