"Ease up Old Timer, we need your help!" Foucarville, 7th June 1944
    • 18932
    Hi Ron
    Looking good....agree ref the gable end timbering though, and would possibly expect a bit more around the wheel pivot as well.....
    • scottie3158
      • 14221
      • Holbeach
      #62
      Ron,
      That looks great personally I think there is enough timbers but it's your build
      • spanner570
        • 15438
        #63
        Thanks for the feed back boys.
        I've added just a single diagonal brace to the gable. Rather like part of a modern roof truss. Keep in mind it's only half a roof.
        I've also added some more metal to the inner parts of the wheel. As most of the middle will be hidden, I just used dark metal paint to simulate the wheel hub bits.
        Not only a dirty thumb nail, but too long as well....Disgusting!............MATRON!
        I've been chewing over ideas for a second building, so that'll be next.
        Cheers.
        Ron
        • spanner570
          • 15438
          #64
          I can squeeze in a small building on the left of the mill.
          Earlier this afternoon I had an idea to try some brickwork inlaid between the structural timber work.
          Here is the front elevation. No paper template, I worked directly onto the foam board.
          Bricks and wood grain scribed onto the board with a scalpel, and then a slurry of Dk. Grey brushed on.
          Cheers.
          Ron
          • scottie3158
            • 14221
            • Holbeach
            #65
            Ron,
            That looks great I did something similar on a previous build.Click image for larger version
            • spanner570
              • 15438
              #66
              Nice work Paul.... :thumb2:
              I'm starting to chop and change a bit too much with the build , so I'm going to concentrate on the stone work.
              Originally I was going to have a simple wooden walkway connecting the mill with the farm track, but have decided to model a stone bridge instead.
              Obviously it needed to span both the mill race and the stream to reach the track. Also, I needed to complete the mill race wall and the face of the weir.
              All the bits.
              The mill race wall, complete with wheel axle hole. The bridge sides and the two components for the weir.
              Pencil and scribed onto foam board.
              An all over dark wash.
              First coat of colour. Painted in cheapo acrylics. The steps down to the track are built up from off cuts of board
              The arches are thin cardboard
              Cheers.
              Ron
                • 15745
                Hi Ron
                Looks great. Love your little bridge.
                You said earlier that the scribing was done with a scalpel. How do you do it? With the point or the flat edge? I ask because when I've tried scribing foam board I have real trouble getting it as neat as yours.
                Thanks
                • spanner570
                  • 15438
                  #68
                  Thanks Jim. I'm glad you like the diddy bridge.
                  To answer your question, after I've marked things out with a pencil, I use the point of a scalpel and follow my markings. I always do this freehand, thus ensuring a few intentional wobbly joints in the stonework....As you can probably see!
                  If a steel rule is used the joints are far too uniform and straight.
                  I would think if you tried to use the flat or back edge of the scalpel it would just tear the board.
                  Cheers.
                  Ron
                  • scottie3158
                    • 14221
                    • Holbeach
                    #69
                    Ron,
                    That is very effective looks really good. I use the same method as you for scribing the board, but using the back of the blade using gentle pressure can give a nice rough edge for rough stone work.
                    • spanner570
                      • 15438
                      #70
                      Ron,
                      Quite right Paul. I forgot to mention to Jim that after I've scribed with the sharp point, I sometimes go over the 'Cuts' with the reverse side of the blade to, as you write, roughen up the stone edges a bit.
                      Sorry Jim!
                        Well stone me :smiling3:.
                          • 15745
                          Ron and Scottie
                          Thanks. You both produce great stone effects.
                          • spanner570
                            • 15438
                            #73
                            Thanks boys.
                            More progress on the stonework.
                            The weir area.
                            Painted up using cheap acrylics (As usual)
                            The right hand end of the mill.
                            The unpainted mill race wall with some serious weathering for behind the wheel.
                            Coffee stirrer boards for wheel access and loading any diddy boats wot come down stream for some flour, grain whatever.
                            General view. Wheel finally fixed and some boards still to be painted.
                            Sluice gate to make, then back to building buildings.
                            The Grebe said it can use the boards to access the wheel to use it as a tread mill to build his strength up so he can improve his karate.
                            Cheers all and thanks for looking in.
                            Ron
                              • 15745
                              Hi Ron
                              Looking good. Looking forward to the water especially all the splashy bits on the wheel.
                              • minitnkr
                                Charter Rabble member
                                • 7551
                                • Dayton, OH USA
                                #75
                                Looks like Roman stonework. Just beautiful. PaulE
