T-18 / MS1 another 1/35 Russian Tank
Jr, see what happens when you disregard Matron's warnings? I should think you would have learned by now that no matter what you try with her she will whack you quicker than Jack Robinson! This vehicle you are building seems to be oooozing some sort of black goo all over the place. Rather messy, don't you think? I heard a reference to some sort of new glue you are trying, it is obviously slow drying as Matron hasn't appeared to pry your digits apart LOL! Glad you are making progress mate. You did the right thing by cutting of the locating pins. In our digital age where computers never make an error, it's the idiots feeding them the information that are EFFED UP, one can pretty much expect this as time goes by. Model on mate! Rick H.:smiling2:Comment
The black grunge is Mr Hobby glue for the mentally impared.:smiling:Comment
You're a madman! I realise that some people enjoy a struggle, but this takes he biscuit.
Seriously John, good for you at having another go at one of these kits. Great work so far.Comment
Many on here would no doubt make something of this, but for me the constant having to re drill every location hole is annoying to say the least.
But I've carried on, nearly all the suspension is built after a fashion, looks a bit odd in parts :smiling4:.
Started on the tracks, surprisingly they actually go together quite well ! Mind I've not come to any drive or ideler wheels, that will be later .
The turret is made out of 6 angled sections, and a top and base. There has been much slicing and sanding, just have one section to fit tomorrow, then the turret can be glued on .
John .
Spent most of the day attempting to get my Moto G6 phone to link to the new pc, just spent a nother hr on the web trying to find where the developer section was on the phone, at last I have found it, and not the way it was suggested on the web ! Nothing seems to be straightforward does it .
Tomorrow may see success in transferring from the phone.
SpComment
Good evening from Race Towers with grey clouds and slight sun here in South Lincs.
Progress has been made and moving on better than expected.
Ok now it's not to the standard that most of you manage but I've nearly got the suspension done, after a fashion.
The fact that I've got if done after I decided that I might have to bury it up to just under the top of the tracks.
The drawing looked most complicated, but working with one section at the time I've managed it
Front sprocket had have a wire glued in, and a corresponding hole drilled in the arm .
Then the parts glued , worked ok.
Bottom rollers on the right look as if they have gone over a rock ! Hopefully the track will follow.
Talking of.
Made a start, very small and have 3 pins one side and 2 the other, so linking is easy but have to be cleaned of flash.
This is where I'm up too, still have the back " parcel tray to do, but one of the bars snapped in two so repairs are on the list .
Thanks for looking in, all comments more than welcome.
Any one seen Steve Jones ?
John .Comment
Just had a pm from Steve, you were right about being on holiday. Been on a tour of Rivet factories no doubt :smiling3::nerd:.
Hopefully the Hobbyboss will be better moulded dimension wise, with pins that fit !
Simon has found a Hobbyboss version, so both of us have sent for one. Considering build mine straight after this and have both of them in one dio.
Thanks for the comments.
John .Comment
