T-18 / MS1 another 1/35 Russian Tank
  • adt70hk
    • Sep 2019
    • 10438
    #46
    Hi John
    Thought it was about time I checked out some of your work afer the warm welcome. I have to congratulate you on your perseverance. It looks like a pretty horrendous build.... I think I would have given up by now.
    I've not come across black adhesive before. If I understood one of your posts it's designed to help you see where you've not glued? Is that correct? How aggressive is compared to say Tamiya Extra thin?
    ATB
    • Steve Jones
      • 6615
      #47
      Don't encourage him Rick.! He will invite you around for a slide show on all the things he's burnt, burning and going to burn LOL
        Originally posted by adt70hk
        Hi John
        ATB
        Andrew the idea was let you see the glue line, in my case its how much I splash about .:disappointed: It does grab but not as quickly as TXT,Iv'e managed to remove parts after 10 minutes so may be less aggressive than TET.
        :tongue-out3:Thank you my dear friend, that is most uncalled for I've hardly set fire to many things, its just spontaneous combustion.:smiling3::smiling3::smiling3::smiling3 ::blow-kiss:
          • 15798
          Hi John
          What a nice looking little tankette. Look forward to the camo - really stupid brave of you :tongue-out3: I like that Revell Contacta glue, very useful when you need a bit of wiggle time.
          Am I alone in thinking the turret looks like a Dalek :rolling:
          • scottie3158
            • 14243
            • Holbeach
            #50
            John,
            Apologies mate I have only just found this and you have nearly finished it. That's a great result so far. Hats off to you for taking on these less than perfect kits.
              Originally posted by Jim R
              Hi John
              What a nice looking little tankette. Look forward to the camo - really stupid brave of you :tongue-out3: I like that Revell Contactor glue, very useful when you need a bit of wiggle time.
              Thanks Jim , Ha .:smiling2: Rick thought it looked like R2D2, Can see the resemblance to a Dalek . I agree with you about the Contactor glue. I don't think I could build a track now with out it.
              Oh as for the camo it might keep a certain member happy !!!
              John,
              That's ok Paul , there wasn't much to enjoy ! more like this is is a crap model and how to bodge it :smiling2:
              John.
                Made 3 wire handles, glued on , painted with MRHobby Metal primer then when dry some Amig primer.
                Going to leave over night to dry as I want to spray a coat of chipping fluid on in the afternoon.Then a top coat of good old 4BO .Can't leave it too long before the chipping other wise it goes too hard and is nearly impossible to do the chipping.
ID:	1104156Click image for larger version
                  Hi John very well done you stuck with it :thumb2: , I thought it was touch and you for a while.
                  Pete.
                  • Si Benson
                    • 3572
                    #54
                    Not โ€˜arf bad mate :thumb2:
                      Pete.
                      Hi Pete. Thank you. Great to see you on the forum again. Take it easy please and do as Siobhan says ! :smiling2:.
                      Cheers Si.
                      John.
                        John.
                        Hi John will do, still in hospital but a lot better place than yesterday, Siobhan is probably ten times stricter than matron so will do as I'm told for a while :thinking:, a short while.
                        Pete.
                        • Mini Me
                          • Jun 2018
                          • 10711
                          #57
                          Looks good JR. It appears that you will survive this event. Have you given any thought as to what you will do next or are you still looking for the matches to your flamethrower?? Glad to see Pete is back with us, I'm sure his missus is keeping a close eye on him so no larking about. Cheers, Rick H.
                            Pete.
                            Stricter than Matron :smiling2::flushed::worried: wow. Respect ! Top lady.
                            Hi Rick yes just got through by the skin of my teeth.Have ordered the Hobbyboss version.So will do that next , and have a joint dio.
                            No we had better look out. I've locked my self in .
                            John .
                              Do the chipping, did it rather too early, but pleased.
                              Only a couple of bits fell off:tongue-out3:, some track and the front suspension arm .
                              See photo, using a tarp to hold up the track while it dries.:hungry: Other section of track is glued and drying .
                              Then the chipping fluid was sprayed, once the brown was dry, then after the chipping was applied the green 4 BO
                              Will glue on the damaged fender tomorrow after doing that track.
                              Have some stuff coming from SMS, including some oilbrusher. In for a penny in for a pound !
                              Thanks for looking in.
                              John .
                              • scottie3158
                                • 14243
                                • Holbeach
                                #60
                                John,
                                I'm glad I'm not the only one that bits fall off. Looking good so far.
