Thanks for your encouraging comments chaps. Much appreciated... :thumb2:
Jim - I can't remember where the thin piece of clear plastic came from. A mega tray of chicken legs perhaps? More than likely from my local tip. I simply cut it to fit around the rocks.
Nearly there....
Poor light for the pictures. I just couldn't get enough underwater detail showing.. :sad:
Anyway, I've loose fitted the boat to make sure everything looks o.k. above and below the waterline.
Any slight gaps will be filled with some water movement.
Next up I'll fix her in position, then start to add a bit of shoreline detail, plus some storm driven detritus. (Rubbish, to you and me!)
Thanks for sticking with the build.
Cheers.
Ron
Nearly there....
Cheers.
Ron
