Cornered, Trapped and Destroyed!...Nov.1944
Tags: None
Thanks chaps.
Jim, good to have you along too. I have to use the foam boards 'cos the missus bought me them for my birthday in March!
Update. After a few quick scribbles to try and liven up the idea department, I've made a start on the building.
It will be exposed brickwork with render to the first floor wall. There will also be some stone work.
Foam board with shop front, 1st floor windows cut out and brickwork marked out.
One coat of beige/brown and one of orange and dk. blue children's 'In the tube' acrylics liberally brushed on and allowed to run where the paint wished to go. I cleaned the brush and using the dirty water, I wiped the brush on the render to take away the harsh white of the board.
A close up of the result. No faffing about, nice and quick and simple.
Before anyone questions the lack of lintols to support the brickwork, the fancy top to the shop window frames will hide where they should be, so no need to scribe them in
Cheers, and thanks for looking in.... :thumb2:
RonComment
This is Mr. Jealous from the back,
Will you please refrain from making these superb buildings, it will do you no good as I will inform the pyrotechnic wizard himself...
Grand job, love the wall texture...
Mike.Comment
Thanks boys.
Having written all that twaddle, it is of course up to the individual just how complicated or simple are the processes they adopts. 'Whatever floats yer boat'
Mike - Don't tell 453, but I already have the matches to hand....Wink, wink!
Tutorial? The same method has been well covered by others (453 for instance) as well as myself in previous builds.
Your Servant,
Vinny van Cough, Goff GoghComment
It's a rotten, wet and miserable day, so I've just finished making this bit of stone work. Originally, this was going to be brick built, but I reasoned there would then be too much of it, so to break things up a bit, stone it is.
Same method as above. I forgot to mention I use a Stanley Knife (Other digit removing tools are available) for the scribing and not my scalpel. Don't ask me why, 'cos I don't know, perhaps it's because the knife is more economical on blades and longer lasting.
This will be fixed to the right hand side of the brickwork.-I think!
Cheers.
RonComment
I'll keep watching, enjoying, and learning :smiling3:Comment
Thanks to both Andy and Ralph for your comments.
Concentrating on the right hand end.....
I never plan what I'm going to do, I just wait for ideas to come along, and in my minds eye I've pictured needing a corner, so I've cut the brickwork and turned the smaller shop front through to 90 degrees.
I wanted the arches set back a bit, so I've added a small return to the building to give me something to fix the arches to.
Here's the frontage thus far.
Next, I'll do summat to the left hand side. That will balance things out a bit and nearly finish the front bit ready for the shop fronts to be fitted and the 1st floor windows.
Cheers.
RonComment
Ron master of the kiss school of getting the best of all from the most basic of items.Comment
