1/35, 88mm flak gun diorama
  • shovelhead 1977
    • Feb 2019
    • 263
    just started this to see how the gun and figures will be placed !
  • JR
    • May 2015
    • 18273
    Ray .
    Seen plaster bandage used on railways, but not on a dio as yet .
    Will take notes.
      • 15696
      Hi Raymond
      Very nice looking start to the dio. I missed the gun build but just had a catch up on that. Beautifully done. So nice to see the figures. I am building the Tamiya 1/48 version at the moment so the photos of your super detailed Dragon kit will be great for reference.
      • rtfoe
        • 9084
        This is the part I like Raymond...the dio base process. Looking good.
        • shovelhead 1977
          • Feb 2019
          • 263
          Ray .
          Will take notes.
          hi john, its a plaster cloth from hobbycraft on offer a pound for 10 cm by 3mtr, thought I would give it a try. not so messy as plaster of paris, you dip this in water , cut to size and put on diorama ! not quite sure what I wanted to do, but it had to be a snow scene as the crew have winter uniforms on. was thinking about a few rocks a couple of trees and maybe an old fence ! got some snow powder so everything will be lightly covered [ to cover any mistakes ! ] have to see how it goes as this is my first ever diorama !
          • JR
            • May 2015
            • 18273
            Thanks Ray.
            Does look ok, sounds a you have it covered scene wise.A few trees to give it some height, fence sounds another good move.
            Plenty of good videos on U Tube from Precision Ice and Snow if you need any pointers.
            • shovelhead 1977
              • Feb 2019
              • 263
              thanks, it was from precision ice and snow I bought my snow from ! may put trees on the long side with fence behind them
              • shovelhead 1977
                • Feb 2019
                • 263
                rough idea how the fence will be, all these two chaps did was sit down !
                • JR
                  • May 2015
                  • 18273
                  I found that the adhesive layering is the hardest part. Putting on the snow as they show is great, esp the angle one for a wind swept scene.
                  • JR
                    • May 2015
                    • 18273
                    Posts crossed there Ray. Just wondering are you going to spray a coat of white over that bandage first to give it a sealing coat, might help ?
                    Looks good set up, the wire placement is damned good, looking fwd to seeing the snow on it :thumb2:
                    • shovelhead 1977
                      • Feb 2019
                      • 263
                      yes will be spraying white over it, maybe a few tufts of grass and a tree stump or two, not quite decided on that yet
                      • shovelhead 1977
                        • Feb 2019
                        • 263
                        started doing the trees, apparently pine trees in 1/35 scale would be about 11 inches, for a 60 foot tree, mine are going to be a little shorter ! but still tall enough to be the right size for the figures, then given a light dusting of snow, thats what i'm hoping anyway
                          • 15696
                          Hi Raymond
                          Coming on nicely. Like the trees.
                          • JR
                            • May 2015
                            • 18273
                            Ray those branches are very realistic could you say what you used please ?
                            • shovelhead 1977
                              • Feb 2019
                              • 263
                              hi john, they are 1/35 pine boughs from panzer models,the trunk is balsa dowling, tried a few different things but they never looked right , either to big or to small but these are perfect ! cut them to what size you want, drill small holes in the trunk and glue them in, will have a light dusting of snow when completed. about 12 quid for 15 boughs , i have ordered some more as i want to put a few more trees on the one side. also if you run a wire brush up and down the balsa dowel it creates a bark like finish !
