The Road to Singapore: Malaya 1941-42
  • TIM FORSTER
    • 283
    • TIM
    • LONDON, UK
    #76
    Another part of the interior that required a lot of work was the interior of the commander’s cupola.
    The hatch is very large - taking up about two-thirds of the turret roof area. With the hatches open the inside is visible even without peering down into the turret interior.
    Now this is one aspect of the kits where the Fine Molds version is actually better than the Dragon equivalent. The Dragon cupola has no interior detail whatsoever, whilst the Fine Molds version does at least have the inside fittings for the hatch hinges and also the small circular vision / pistol ports. However, what neither kit offers are the impressions of the six horizontal and two vertical vision slits which surround the cupola itself. There are also two prominent vertical weld beads inside because the cupola ring itself was made from two semi-circular pieces.
    [ATTACH]411271[/ATTACH]
    Ha-Go Restoration
    You can see the inside of the vision slits and one of the weld beads in this image of a restored vehicle.
    When I was sill intent on fiishing the Fine Molds kit, I tried to drill out the vision slits all the way through from the outside using a very fine drill. This was only partially successful - partly because the Fine Molds cupola is also way too thick. Once I had the Dragon cupola (which is at least thinnner) I decided a different approach.
    Here you can see the two cupolas side by side with the Dragon part on the left and the FM one on the right (the reason that the FM one is grey and not dark green is because I had sprayed it with primer to see how well my work had gone - I was not impressed!).
    [ATTACH]411272[/ATTACH]
    Comparison between the two cupolas
    Next I cut out two strips of thin plastic sheet which were the right size to wrap insde the Dragon cupola and cut the vision slits into them.
    [ATTACH]411273[/ATTACH]
    Cupola interior inserts
    These were then glued inside and, once dry, sanded to make them as thin as possible. Next I transplanted all of the hinges, etc from the FM part into the Dragon cupola. I also added some bolt heads from slices of stretched sprue and the weld beads from the stretched sprue also, softened with liquid cement and then pressed gently with a knife the make the weld beads.
    [ATTACH]411274[/ATTACH]
    Cupola interior complete
    It looks a bit messy here, but once everything was painted I was quite pleased with my efforts.
    [ATTACH]411275[/ATTACH]
    Interior weathered
    [ATTACH]411276[/ATTACH]
    Interior weathered
    [ATTACH]411277[/ATTACH]
    Interior hatch details
    In this last shot you can also see the replacement grab handles and hatch latches which I added to the Fine Molds hatches using brass wire and spare photo-etch strips. These were moulded solid on both the FM and Dragon kits, so you have to make them which ever kit you buy. It’s an odd feature of many of these kits that they give you 3D handles for use on the outside, but seem to think it is acceptable to mould them as simple raised details on the inside of hatches - even when you want them positioned open.
    The final detail I added to the inside of the cupola was an AA mount for the MG (from a small piece of brass tube). I believe that not all Ha-Gos were equipped with these, but if you look carefully at the shot of the second tank at Bakri (with the dead crewmen alongside) you can just make this out. The FM kit also had the mounting brackets in the correct position, but not the tube.
    [ATTACH]411278[/ATTACH]
    Here is the finished model before exterior painting begins...
    [ATTACH]411279[/ATTACH]
    • scottie3158
      • 14201
      • Holbeach
      #77
      Tim good to see you again and what away too come back. Excellent work on the updates and scratch work. It will look stunning with some paint on.
      • rtfoe
        • 9086
        #78
        Fantastic comeback Tim. The Ha-Go un-identical twin looks much better and the switch over was a good decision even if the mantlet on the FM kit was easily repairable. Funny as FM is always seen as the finer molded kit...no pun intended. :tears-of-joy:
        • JR
          • May 2015
          • 18273
          #79
          Some really fine work there Tim, a credit to your determination.
          • Steven000
            • Aug 2018
            • 2828
            • Steven
            • Belgium
            #80
            Nice details! Well done :thumb2:
            • adt70hk
              • Sep 2019
              • 10409
              #81
              Great work there Tim. Well outside of my expertise!
              ATB.
              • stillp
                • 8093
                • Pete
                • Rugby
                #82
                Welcome back!
                • Peter Gillson
                  • 2594
                  #83
                  Great work on the interor.
                  Peter
                  • Neil Merryweather
                    • Dec 2018
                    • 5189
                    • London
                    #84
                    Amazing stuff there Tim- I'm full of admiration!
                    • TIM FORSTER
                      • 283
                      • TIM
                      • LONDON, UK
                      #85
                      Sorry for the long silence... work picking up and two teenagers doing A levels and GCSEs respectively hasn't helped!
                      But, rest assured, progress is being made!
                      A few more details before I get on to painting…
                      One useful part of the Fine Molds kit which did not come with the Dragon equivalent was the mould for the photo-etched muffler guard. Here is the Dragon PE wrapped around it…
                      The Fine Molds kits also wins the prize for the most detailed maker’s plate on the front glacis. However, you can also see details from the Dragon kit, such as the armoured MG sleeves, which are far superior to the FM offerings.
                      Below, in stills from the cine footage taken soon after the battle, you can also see the two ragged holes caused by the 2-pounder HE rounds. These were made in the usual way by thinning out the plastic from behind and then punching the holes with a craft knife. I have tried to replicate the real impacts as closely as possible…
                      • TIM FORSTER
                        • 283
                        • TIM
                        • LONDON, UK
                        #86
                        Now before I started this project I knew almost nothing about Japanese tanks. There’s still an awful lot that that I don’t know…
                        However, having looked at a lot of on-line images of the Ha-Go I noticed one aspect of the tanks used in Malaya - or at least in the Bakri action - which differs from most other Type 95s: at least some of them have a large rectangular box on the rear port trackguard which sits behind the standard metal bin. Once I started to assemble the kits (both the Fine Molds and Dragon ones are the same in this respect) this began to puzzle me, because this box is in the same position as the jack and other tools, all of which have specific mounting points which would otherwise be in the way of this box.
                        [ATTACH]429296[/ATTACH]
                        [ATTACH]429297[/ATTACH]
                        The clearest view of this box is that on the second tank (shown in the lower image and in the background of the one above). Even though it is partially destroyed, it is possible to see how it overhangs the track guards thermselves and was held on the vehicle by a length of wire or rope. As for what the box contains I have no idea. It also appears to be of fairly flimsy construction - so perhaps made of thin wood or even cardboard.
                        Also visible in the same image is the wrecking bar (with a length of chain wrapped around it) and mounts for the other tools which were mounted on the side of the engine compartment - and not the track guards - which would explain how the box was able to be placed in this position. What happened to the jack, I have no idea.
                        The only other Ha-Go I have come across which has a tool layout which is in any way similar to the Bakri tanks is the one in Bovington Tank Museum. I believe this Type 95 was captured in Burma. It was later examined in Calcutta before being sent to Britain.
                        [ATTACH]429298[/ATTACH]
                        [ATTACH]429299[/ATTACH]
                        [ATTACH]429300[/ATTACH]
                        [ATTACH]429301[/ATTACH]
                        This Ha-Go, which appears to be in good condition, still has one smaller box behind the official stowage bin, although on capture it clearly had yet another as well. It also has no mounting point for the jack and you can see the clamps for the other tools (crowbar, spade and pick) on the front port trackguard - so a third variant.
                        By the way, there is a great walkaround of this tank from the museum’s curator David Willey at: Tank Chats #50 Ha-Go | The Tank Museum - YouTube 1
                        The tank is sealed, by the way, because of the asbestos which is still inside it and, as he helpfully explains, the camouflage scheme is completely spurious.
                        So I replicated the tool clamps from spare photo etch and made a crowbar from a piece of metal rod with the ends sanded to a suitable profile. You can see my attempt at scratch-building the box from thin plastic card in the images of the model below, in its finished state state prior to painting.
                        [ATTACH]429302[/ATTACH]
                        [ATTACH]429303[/ATTACH]
                        [ATTACH]429304[/ATTACH]
                        [ATTACH]429305[/ATTACH]
                        [ATTACH]429306[/ATTACH]
                        Oh yes, one last word on the tracks. The Fine Molds kit comes with the link and length variety, which are OK, but lacking in detail. The Dragon kit comes with the ‘rubber’ full-length type, which some people love and others loath. I have so say, they look very nice detail-wise and the only issue would be getting the right sag.
                        So I went for the Friul model option. Now I have heard from a few people that the quaility at Friul may be slipping and I have to say these ones bear that out. Not only was there quite heavy metal flash on many of the links, my box also came with two port sided pairs.
                        • Mini Me
                          • Jun 2018
                          • 10711
                          #87
                          Hi Tim....between FM and Dragon you have a very fine tank there.......looking forward to the wet stuff. Oh, and welcome back, you have been missed. Rick H. :thumb2:
                            • 18907
                            Nice work Tim. Looking very good, with excellent supporting research.
                            • Neil Merryweather
                              • Dec 2018
                              • 5189
                              • London
                              #89
                              Great to see this revived, very enjoyable. Welcome back
                              • scottie3158
                                • 14201
                                • Holbeach
                                #90
                                Tim great to see you back, and what a way to return. An excellent build.
