Zvezda SU - 100 1/35 SCALE & BM truck
  • JR
    • May 2015
    • 18273
    #16
    John,
    Looking good mate.
    Thanks Paul .Tried it with the wheels and they all sit on the floor !
    • Mini Me
      • Jun 2018
      • 10711
      #17
      I'll keep an eye on this as you progress JR, but before Mr. T shows up, is that a large body seam on the back of the cab above the seat that my "Jaundiced" eye doth spy?:thinking:
      • Steven000
        • Aug 2018
        • 2827
        • Steven
        • Belgium
        #18
        Nice project John :thumb2: .
        I actually sold that same SU-100 kit this month because a lack of time...
        Will follow your build instead :tongue-out3:.
        Steven
          • 22770
          #19
          Just seen this one John, a very nice start indeed. Looking very good.
            John,
            you seem to have mastered that PE - I also leave the tiny parts alone, life isn't long enough to use every part on the etch sheet! :thumb2:
            • spanner570
              • 15402
              #21
              Nah! sloppy Friday afternoon welding at Factory 16.....
              Good progress 453
              570
              • rtfoe
                • 9084
                #22
                Speedy Johnzales...ju beeeld very quiiickly. :smiling6: And you're doing fine with the bling. A choice between a city or countryside...it will be great to see rolling grassland of the Russian steppes.
                Got my seat ready.
                • JR
                  • May 2015
                  • 18273
                  #23
                  Oh yea of little faith. Rick that is just a poor weld in the BM factory. :smiling3::smiling3::nerd:.
                  Steven
                  Your most welcome Steven, could you swear as we go along please !
                  Thanks Ian, grab a seat before the rest of the Rabble arrive.
                  John,
                  Thanks Dave, its taken me long enough to grasp it. Oh I agree about the small stuff, just not worth the bother. I saw a PE set the other day with individual bolt heads, smaller than .5 mm !
                  John.
                  • JR
                    • May 2015
                    • 18273
                    #24
                    Good progress 453
                    570
                    570 Greetings from the wind swept stepps of Lincs.
                    Got my seat ready.
                    Hi Richard, good to have you along.
                    Still undecided on the dio setting , but it will be showing reloading. We'll have a vote later ! I've put you down for the rolling grassland .
                    John.
                    • JR
                      • May 2015
                      • 18273
                      #25
                      Not much to show, started the Masterclub Tracks.
                      Not one fits with out much prep, in the end I'm using 4 mm brass wire, having to straighten most of the track plates out. Very soft material, so drilling each one after removing casting debris attempting to join up and running the drill through, promptly followed by the wire.
                      With the resin pins being so thin only a few go in, hence the wire.
                      John.
                      • tr1ckey66
                        • Mar 2009
                        • 3592
                        #26
                        Hi John
                        Very nice start to the SU 100 - nice textured hull and PE. The truck will make a good company for the tank destroyer.
                        Paul
                        • Steve Jones
                          • 6615
                          #27
                          Bling tastic Mr Race!! With your eyesight issues this must have been like climbing Mt Everest for you. Very proud of what you have done. Good luck with all those track links. Here are a few photos if you need them. SU 100
                          • JR
                            • May 2015
                            • 18273
                            #28
                            Originally posted by tr1ckey66
                            Hi John
                            Paul
                            Thanks Paul,off to check out some BM trucks now to work out the rear body .
                            Hi mate, took a bit of time to adjust, but getting the hang of it now. Thanks for that walk round, see there was another light on that one, will check the sprue as I think it was on a double one so might be a apart light.
                            Those tracks will just have to take time, ordered some more .4 wire, so tomorrow will use up the wire then concentrate on the. BM rear bed .
                            John .
                            • Lee Drennen
                              • 7711
                              #29
                              • JR
                                • May 2015
                                • 18273
                                #30
                                Not a bad day, had a CLEAN UP as well , and brought out the new cutting mat. (Reason for all this was knocking over a bottle of CA, of course stuck one corner of the mat to the bench.
                                Half a bottle of debonda later, followed by a clean and we have this .
                                It lasted about an hr until I filled it with spur and parts.
                                Been making the load bed for the truck.
                                Used 1mm plastic sheet for the deck, and .8 for the sides back and head board.
                                John.
