Zvezda SU - 100 1/35 SCALE & BM truck
    Wonderful work John, despite the distractions of the Rabble.
    • SimonT
      • 2824
      #47
      Truck bed looking good John
      • JR
        • May 2015
        • 18273
        #48
        Originally posted by Si Benson
        Lovely work Mr R
        I see the TBC have rejected your Membership application again..one day mate, one day :smiling5:
        Good to see you didn’t glue yourself to the table :thumb2:
        Hi Si. Don't think I'll ever be accepted.
        Gluing my fingers to better was enough. I saw the bottle fall, the rest is a blur. Dont think I've moved as fast in my life ! :sad::nerd:.
        Thanks Peter. The Rabble come with the territory, it's a cross I have to bare !:smiling2:
        Thanks Simon, unfortunately I didn't have any round plastic strip for the rivets, and the bolt heads I had were far to large. Apart from the odd line they are in I'm pleased .
        • stillp
          • 8093
          • Pete
          • Rugby
          #49
          See now John, if you had a properly untidy bench there wouldn't be room for bottles to fall over!
          • JR
            • May 2015
            • 18273
            #50
            Quite so Pete, :smiling2: but it happened when the bench was full to bursting !
            • stillp
              • 8093
              • Pete
              • Rugby
              #51
              As it should be John. :thumb2:
              • JR
                • May 2015
                • 18273
                #52
                Right here at Race Towers we have luckily not had any flooding, mainly due to being on high ground , hope every one is dry elsewhere on here.
                Much happening with the SU -100 as follows. Ok some of the PE has had to be re glued but that's down to now trying to use a lot less.
                Now I'm quite a lover of aftermarket metal tracks, usually use Friul, but this time I went for Masterclub, which I've used before with no problem. These were a different kettle of fish, many were bent, full of casting debris, most needed drilling ,and each one had to be checked to make sure they were level. Mike had the same problem as well with some he had for his Centurion build.
                The resin pins have gone it into the rivet spares box , it was just a complete waste of time, so out came some .5 wire left over from a set of Friuil's. Apart form the debris I think the bent sections were down to poor packaging from the vendor. No its wasn't Historex Agents, as they didn't have any stock at the time !
                So the tracks are done, just waiting for some paint.
                Bit of a gap on both rear guards I thought i'd cut the plastic off to the correct size, so next time will remove less until the final fit.
                Now I had to remove that top gun shroud and fit some small pe hinges from the spares box, it had plastic hinges moulded on, so it must have movable.
                This happened due to getting the driver in his opening, after a short struggle, he eventually went in and was glued to the gun mantle.
                Then added some extra links for additional protection.
                Figures are coming on .
                I've fitted some brass handles since these photos, just need to apply a coat of Mr Hobby metal primed and painting can commerce.
                As for the BM truck . Click image for larger version
                Took the windscreen out and cleaned as per help received form my post on clear parts.:thumb2: going to try to get them beck in with out too much glue.
                A few items to put in the cab.
                There's a rifle as well
                On the back of the cab there is enough room to add a pickax and a shovel , just to add some interest. The folded tarp by the way was my first attempt at using VMS paper fold, thing any suitable paper could be used , but it certainly look ok. A lot easier than imagining me with a rolling pin and some 2 part putty ! :smiling2:
                Thanks for looking in comments more than welcome, along with any abuse :upside:
                John.
                  • 15693
                  Hi John
                  Good progress. Figures look nice. Figures always add to a dio. Shame about tracks requiring so much extra work.
                  • JR
                    • May 2015
                    • 18273
                    #54
                    Originally posted by Jim R
                    Hi John
                    Thanks Jim.
                    • scottie3158
                      • 14201
                      • Holbeach
                      #55
                      John,
                      Sorry mate not sure how this has passed me by. The work on the cargo bed is excellent mate you should be well chuffed with that. The rest of the build is on the ball as well.
                      • minitnkr
                        Charter Rabble member
                        • 7538
                        • Dayton, OH USA
                        #56
                        Looks to be another winner Dzohn. Some great scratchery. PaulE
                        • Steve Jones
                          • 6615
                          #57
                          Wow! The tank is looking the DBs. It seems the driver is none to happy about the tracks either. Will PM you about those. The truck is coming along really well. Nice to see the odds and sods going in the cab. Top work all round mate.
                          • JR
                            • May 2015
                            • 18273
                            #58
                            John,
                            Paul, oh its easy to miss stuff alright. Thanks for the comment.
                            Hi Paul, thanks , I enjoyed that part.
                            Hi mate, pm received and answered:upside: Yes Dmitry was none to pleased that those tracks , replacing every track bolt took him days.
                            Just in .Click image for larger version
ID:	1115559Click image for larger version
                            Taken quite soon after painting , got the cab painted and then realised the windscreen wasn't in DUD. What am I like ?
                              Hi John this is taking shape very nice indeed keep up the good work.
                              Pete.
                                Quite the update John, it's looking great. Loving all of the extras.
