Zvezda SU - 100 1/35 SCALE & BM truck
  • SimonT
    • 2824
    #61
    Those Masterclub tracks look pants compared to their usual quality
    I have previously used their resin ones which have been great - have a couple of the new metal sets but not opened them yet so I just hope they don't turn out as bad
      Originally posted by Pete Low
      Hi John this is taking shape very nice indeed keep up the good work.
      Pete.
      Thanks Pete, still untidy compared to most on here though.
      Originally posted by Paintguy
      Quite the update John, it's looking great. Loving all of the extras.
      Yes Andy it was , more to come today
      Hi Simon, Steve "Rivet " and I were discussing them in a pm, they arrived with the sleeve completely flat and the links were wrapped in a plastic bag. think we both are of the opinion that they might be counterfeit, not something I would buy knowingly. I had always liked them before, but this time Historex Agents didn't have any. To be fair the bends might be down to bad packaging, but not the debris on the links.
        To day I managed to get all the decals on, always think the model starts to come to life now. On the SU I did some mini ropes around those wooden cases on the back, and put the tow cables in place.
        BM had a pickax and axe put on the wooden back board. All clear lamps were put on.
ID:	1115624Click image for larger version
ID:	1115625Click image for larger version
        After the decal setting has been done I need to check all is painted, ready for the varnish.
        Not going to be a lot of mud on the tracks as there will be snow , so will have to see how it pans out. Any tips more than grateful .
        That thread does give a quite realistic rope, its by COATS.
        BM.
        Thanks for following and the comments.
        John.
        • Steven000
          • Aug 2018
          • 2830
          • Steven
          • Belgium
          #64
          Looking very good John, nice progress and some lovely details :thumb2:
          Steven
            Steven
            Thanks Steven.
            • Si Benson
              • 3572
              #66
              Evening John,
              all looking very smart indeed :nerd: recovery cables and stowage look great
              • scottie3158
                • 14243
                • Holbeach
                #67
                John,
                All looking very nice indeed.
                • grumpa
                  • Jan 2015
                  • 6142
                  #68
                  All looking good John, one would think you've done this sort of thing before.
                  Great attention to detail, am watching your build as always.
                    Fantastic work John.
                      Originally posted by Si Benson
                      Evening John,
                      Thanks Si.
                      John,
                      Cheers Paul.
                      Hi Jim, nice of you to drop in, suppose your knee deep in snow up there in the wilds.:surprised:.
                      Thanks Peter.
                      Hopefully to day I will get some parts on the SU painted , like those extra tracks and wooden boxes.
                      Been thinking about Pine Trees, I've seen some on a build by Paul and " Shovelhead" Ray kindly gave me an address for Panzer Models who stock the branches.
                      I can see this year I'll be growing both sea grass and asparagus ferns :nerd:
                      Thanks for the comments.
                      John .
                        • 15798
                        Hi John
                        That is looking better and better. The little extras like the ropes are worth the effort.
                          Originally posted by Jim R
                          Hi John
                          Cheers Jim. Not as hard to do as I expected, just fiddly. Agree they are certainly worth the effort.
                          • Steve Jones
                            • 6615
                            #73
                            Very nice JR. Some of your best work yet. Lovin the bent fenders. Expect to see those on all your AFVs from now on :smiling5:
                              Very kind of you to say Steve. Think the overall green is a bit heavy on the SU, I'd had a mix up of tips.
                              There will be some PE fenders plus other goodies on another KV-2 Build !
                                Evening, don't know where you are but the winds got up again.Lovely sunny day after a wet morning.
                                Right moving on, started on the dowel, to make things quicker I inverted my 100mm belt sander and thinned down the dowel.
                                Then rinsed in water, to lift the grain and dragged the saw down the length, gives a reasonable bark texture.
ID:	1116069Click image for larger version
                                These will be de -nibbed once dry with a light sanding.
                                As the ammo cases arrived yesterday i'd made a start on the boxes. Nice clean moulding, the decals are so small , so will have some fun, but iv'e used them before with success.
                                Bit of over glue, think I need to use a much smaller brush for this sort of kit, may be an old No 7 .
                                Several weeks ago I glued up a section of insulating foam to a ply base, left it with weights on. Today started the shaping. I wanted to have some high at the back, so to increase this I removed about 30mm from some of the base.
                                Marked out and numerous cut made into the foam at the depth of a Stanley knife blade.
                                Then cut another section to give the total high, with a smaller piece on the left.Click image for larger version
                                That last piece will be glued later, but first the main part.
                                UHU for foam applied each side, then rubbed joined to remove any air and to spread the glue out weights and pins were applied.
                                Just to give an idea of where the truck and SU will be.
                                Thanks for looking in, comments welcome.
