Hi Richard
Now that's what I call detail painting. 1/700 scale - that's incredible.
Thanks Jim, with Vallejo acrylics and not rushing it is very enjoyable to detail paint in thin coats and slowly building up the weathering effects. The ships are going to be the next fun subject for weathering with acrylics.
I really enjoy your dioramas, Richard. They are always full of such intricate detail, especially this one !
John.
I tend to revisit my dios that have been neglected and improve or add detail that I have learned through the years. This dio is easily 20 years in the making and was stalled by PE and rigging which caused me to work on the harbour more. Glad you like it.
Originally posted by adt70hk
Damn that's good Richard!!
Very well done indeed.
ATB.
Sometimes I sit back and marvel at what I have achieved. Don't think I'd be able to do it all over again.
The right side of the dockyard kind of looked empty so I decided to add oil storage facilities. It's a small wedge of space so I sawed the Tamiya oil storage structure using less than a quarter of it.
The flat surface needed detail so I will add stairs to the side and railing at the top...you can see I have marked out in pencil where the stairs will go.
I've got the platforms cut out similar to the what's on the giant crane legs. I'm using PE for the oil container and solid stairs which I have engraved on a piece of plastic strip that will be sliced and cut into correct lengths. PE railing will be attached to the sides.
Lots of work to be done on the giant crane with cabling and hook.
I added backing to the cut side of the oil storage tank with plastic card and a bit of plastic putty filler.
Then did a crazy thing by adding weld beads for the sheet walls of the tank...
Okay...a bit more today...fitted in the platform and zig zag stairs and railings to the top but still needs railings to the individual platforms. The bottom lip had to be sliced off to fit the spot intended. I didn't compensate for the extra bit of the backing.
Good Golly Richard!!! I just did a ketchup on this with the optivisor on. This is most beautiful and exquisite work Sir. Micro madness at it's best!!! It's no wonder you have to take a break from it as if you didn't, you'd go blind for sure.............
Allen
Thanks Allen, good to have you back and yeah I am struggling with the eyes even with the magnifiers the focus goes blurr if I stare more than 10 minutes at the object that I'm working on.
I'm also working on the giant crane stairs...
Got the engaved stair s placed and will add the railings.
