Great work.
1/700 scale IJN Ships make over
A bit more done just now on the giant crane with railings and ladders...
I added a door at the end of the walkway. The kit doesn't show any way into the work house so I'm improvising. I'm sure there is a way in but was too lazy to search for reference and not too worried of riveteers. Might do another walkway and door on the opposite side...perhaps entering higher to another floor level with stairs leading to it from the walkway...that would be interesting. I can really go bonkers with this.
RichardComment
[ATTACH=CONFIG]n1176461[/ATTACH]
RichardComment
Hi, made more progress on the giant crane...
Raised stairs on the opposite side and started on the cabling pylon structures.
Made the cable pulleys...if you think it looks like something else pls keep it to yourself. :smiling6:
Cabling with stretched sprue to be continued to the engine house.
Meanwhile I scratched an engine house for the base...no plans just gyzmology. Will add a huge pulley somewhere.
That's all for tonight.
RichardComment
More fantastic work Richard!!! This is just so cool and so tiny......Now remember, Take off optivisor, get up from the bench slowly, watch out for the door frames, walk carefully and feel your way to the sofa, sit down, close your eyes and take a rest. After 20 minutes, your poor vision will (hopefully) get back to normal..........
Allen (M.D. at large)Life's to short to be a sheep...Comment
Hi Scottie, thanks for that compliment although tbh at close up it looks a bit messy.
Potion...I mean Patient No.9Comment
I have been busy at the LHS and managed to add more PE and the final cables to the crane. The next thing I did was giving it a few coats of varying shades of Hull red or red primer after masking the engine shed...
There are at least four shades from dark brown to a light orange.
Shades very evident on the leg structure...a form of modulation.
I will highlight the railings, stairs and ladder with silver as all the PE is guess work and running wild with the detail.
Pulleys will be painted in black and cables probably in metallic grey.
While the paint cures before the weathering and highlights I will further work on the lower engine shed.
RichardComment
