1/700 scale IJN Ships make over
  • Code no 10
    • Jun 2022
    • 130
    #241
    The water effect is absolutely brilliant, Richard. The waves scale and colour is so fitting. :thumb2:
    :thumb2::thumb2::thumb2::thumb2:
    • rtfoe
      • 9099
      #242
      Originally posted by stillp
      That's crude??? :rolling:
      Yes crude. The real ones had a circular disc base with measurements to the ships course and direction...I didn't do that. :smiling6:
      • rtfoe
        • 9099
        #243
        Thanks Hong, if you're anywhere in KL on the 30th of this month, drop by at CKTan hobby shop. We're having a GB for Ships and Helis.
        Noticed your avatar is a Phantom. You get to meet many Phantom Sifu's at the GB. CKTan is at Bremmall just off jalan Ipoh in Kepong.
        • rtfoe
          • 9099
          #244
          Hi,
          Just painted the binoculars and pulleys...
ID:	1180873Click image for larger version
          • rtfoe
            • 9099
            #245
            Hi Guys,
            This is only the rusting stage of weathering...
ID:	1180931Click image for larger version
            Letting this dry before adding dark streaks and lighter bits of chipping.
            • Mini Me
              • Jun 2018
              • 10711
              #246
              Very nice Richard.....keep it coming. :thumb2:
                • 15737
                Great work Richard at this very small scale.
                • rtfoe
                  • 9099
                  #248
                  Thanks guys, will do and will rest my eyes in between stages of painting. While waiting for the layer to cure I made an aerial tri-mast to be positioned on the C turret which holds up the rigging to the rear. Also added railings to the back of the pagoda structure after painting the deck linoleum red brown. Will get some images up.
                  Richard.
                  • Code no 10
                    • Jun 2022
                    • 130
                    #249
                    [ATTACH=CONFIG]n1180872[/ATTACH]
                    Thanks for the invite, Richard. Will likely drop-by to look see, and watch modeller sifus at work. May I know what time the event start and end?
                    • rtfoe
                      • 9099
                      #250
                      Thanks for the invite, Richard. Will likely drop-by to look see, and watch modeller sifus at work. :smiling3: May I know what time the event start and end?
                      Hi Hong, the committee still hasen't announce the time but I think its safe to be there at 12pm and it should end around 4pm. It's near the shop and you'll be surprised at how well stocked it is. Don't blame me if your wallet gets burnt. :smiling6: Members get a 25% discount...I'm going to leave my wallet at home.
                      • rtfoe
                        • 9099
                        #251
                        As promised piccies of the aerial tri-pod...
                        I used brass wire and stretched sprue with CA for bonding...
                        Test fitting and cutting one end of the leg shorter as it stands on the sloping turret top.
                        Painted up and glued down.
                        The railing attached. Lucky I had the foresight not to glue down the pagoda structure.
                        You can barely see it with the structure on.
                        Added railings to a receiver platform or some sort of antennae.
                        • Code no 10
                          • Jun 2022
                          • 130
                          #252
                          Thanks for the info about the time of the event, Richard. Those shiny, plastic wrapped model boxes sure can make my legs go so weak. Hahahaha, I suspect the event organize at end of July was to coincide with "gaji masuk" time. Those sly bastards:thinking:
                          • rtfoe
                            • 9099
                            #253
                            Seriously, when see shop and the goodies... sure "pengsan wan". "Gaji" sure "habis tapau". No need go Singapore buy kits. If wan Kinetic, Airfix and Zvesda then go Area88.
                            Sorry guys...we're talking Malaysian 'Engrish' laced with local words/slang.
                            • rtfoe
                              • 9099
                              #254
                              Hi guys, I was lazy to weather the opposite side of the Haruna so to find a way out I had this idea...since it's a refit I thought the Haruna was also being painted so one side is complete and the other is in progress...
                              The platforms will be decked with sailors and paint cans busy at work.
                                • 15737
                                Hi Richard
                                That's a nice idea. I don't think I've ever a model of a ship in the process of being painted.
