Last Ditch
  • Jack L
    • Jul 2018
    • 1270
    • Cheltenham
    #16
    Thanks Jason. The drain cover is made of scrap sprue...although see now that one of the bars has slipped. Will have to cover it with some debris! rtfoe to thank for the inspiration on that addition though.
      Terrific work Jack. All looking very nice indeed.
      • Jack L
        • Jul 2018
        • 1270
        • Cheltenham
        #18
        Thank you Peter.
        A 'productive' day and still a fair bit of minor tinkering to do, but the main bulk is done. Some weathering still needed on the buildings, and then to blend the model to the base...then a fair bit of work on the figures, most of which arrived this morning. If you spot anything that needs work, or doesn't look right, please pipe up! I have been staring at it for too long! Thanks for taking the time to look.
        Jack
        • Jason Crausby
          • 658
          #19
          Brilliant job Jack...are you going to throw in a bit of dust... would look spot on!
          • outrunner
            • Apr 2019
            • 2420
            #20
            That looks really good, wish I had the skills to do something along those lines.
            Andy.
            • SimonT
              • 2824
              #21
              Hi Jack - looking good
              One minor thing to note for future - use non-patterned tissues for tarps. That looks like kitchen roll - you can see the embossed pattern in it. The drape, creasing and paint look good though
              More rubble in general plus a bit more dust and small rubble, both inside the building and out, would add to the look, as Jason mentioned - when buildings come down it all has to go somewhere and there is a lot of material making up a building
Name:	Screen shot 2010-04-27 at 06.45.51.png
Name:	Screen shot 2010-04-27 at 06.44.25.png
              This stuff that John sells would be ideal Urban Scatter
              or you can take a hammer to a spare house brick or plant pot and brew your own
              Dio also needs rubble on the first floor
              Hope that helps
              • spanner570
                • 15389
                #22
                Excellent progress Jack.
                The model is 'Under construction' and not finished, so I'm sure as it proceeds, you will have plenty more ideas for stuff you will be adding to an already good looking diorama.
                You must be well pleased with how it's shaping up....
                Ron
                • Jack L
                  • Jul 2018
                  • 1270
                  • Cheltenham
                  #23
                  Thanks very much Jason, yes will be plenty of dust...will be the final step when the figures are in.
                  [ATTACH=CONFIG]n1126424[/ATTACH]
                  [ATTACH=CONFIG]n1126425[/ATTACH]
                  Hope that helps
                  Thanks Simon
                  The original tarp was a bit of an experiment, but then it came out quite nicely so I decided to stick with the Aldi bog roll pattern, hoping it wouldn't be noticed. I do have some 'industrial' tissue on a big roll but am finding it doesn't 'fall' in quite the right way. The paper itself is a bit shinier.
                  Thanks for the suggestion of more rubble, I will add that. Helps having a second opinion there, I never know if I have gone too far/not far enough. And had not considered 1st floor rubble...great point! Yes will definitely be a fair bit more weathering and a hefty layer of dust on the way.
                  I note the model is 'Under construction' and not finished, so I'm sure as it proceeds, you will have plenty more ideas for stuff you will be adding to an already good looking diorama.
                  Ron
                  Thanks Ron...yes still plenty of tinkering to go. Enjoying this a lot, and learning plenty of dos and don't as I go.
                  • Jack L
                    • Jul 2018
                    • 1270
                    • Cheltenham
                    #24
                    Andy.
                    Thanks Andy....this is my first attempt at a Dio, and it is surprisingly straightforward to get a really good effect. Looking through peoples work on here, and the odd youtube video are great inspirations...then your imagination is the limit.
                      • 15678
                      Hi Jack
                      That 88mm looks really good. The dio base is coming on a treat.
                      • Gary MacKenzie
                        SMF Supporter
                        • 1057
                        • Gary
                        • Forres , Moray , Scotland
                        #26
                        I found a ''lidl anti bacterial wipe'' once washed ( to get rid of anti-bac in it ) and dried has a nice canvas type surface to it.
                        • scottie3158
                          • 14201
                          • Holbeach
                          #27
                          Jack,
                          All looking very good.
                          • Jack L
                            • Jul 2018
                            • 1270
                            • Cheltenham
                            #28
                            Originally posted by Jim R
                            Hi Jack
                            Thanks Jim!
                            I'll have to have a play with a few variations!
                            Jack,
                            Many thanks Paul.
                            Have bombarded it with a fair amount of homemade rubble, and agree it looks much better and more realistic now...not sure where the figures are going to fit...but will work that out when they are painted!
                            • Jack L
                              • Jul 2018
                              • 1270
                              • Cheltenham
                              #29
                              Was going to say the first two candidates are ready to go in...but after uploading the photo I just realised I have not finished with subject no.2's helmet. I find figure painting tough (and often frustrating) so has taken me about a week to get these two to this stage, and a couple more at the half way point. I am ignoring the 'White Walker' eyes...
Name:	Screen Shot 2020-06-20 at 11.20.53.png
ID:	1127151Click image for larger version
Name:	Screen Shot 2020-06-20 at 11.20.37.png
ID:	1127152Click image for larger version
Name:	Screen Shot 2020-06-20 at 11.20.23.png
ID:	1127153Click image for larger version
Name:	Screen Shot 2020-06-20 at 11.20.13.png
ID:	1127154Click image for larger version
Name:	Screen Shot 2020-06-20 at 11.20.02.png
ID:	1127155Click image for larger version
Name:	Screen Shot 2020-06-20 at 11.19.43.png
                              • SimonT
                                • 2824
                                #30
                                Morning Jack - the increase in rubble is looking good :thumb2:
                                One thing to consider - there is a lot of red brick rubble but the walls are all grey :thinking:
