Hi guys. Been busy the last few days working on my next dio. Only a small one this time.
Not going to tell you exactly what I'm doing just yet, but made a start on the base:
The pavement and wall are just 6mm foam. The slabs and brickwork were marked out using the same method that Ron uses - and if it's good enough for him, it's for certain sure good enough for me! Scribed first with a shallow cut with a knife, then run a pencil along the cuts to create the joints. Bashed around on the wall a bit with an old piece of brick to create dents and dings. Still got to do the paving and road but not sure yet just how old and battered I want them.
Painting was done with some of those old powder paints we all used in infant school. Mainly red and yellow with black spots here and there to darken it. I used a big soft brush and literally just splashed the paint on and stirred it around.
There will be a tree in the middle of that bench. The underbrella is from Lego.
I've not done too much work with wood and I need to darken the balsa I've used for these. Can I use really well thinned Vallejo acrylics to make my own stain?
