Just a teaser Completed
  • Gern
    • 9226
    #76
    Originally posted by monica
    very well done on the two,girls Dave,they are goods,always very hard to find civilian,s
    juust a couple of washs on them and alls good,have to ask where did you find them please
    Been in touch with the seller Moni. No luck I'm afraid, he got them from ebay himself a couple of years ago. Sorry I can't help.
    • Mini Me
      • Jun 2018
      • 10711
      #77
      Preiser make some figs. that are very similar in 1/24 scale, give them a try and see if there is anything of interest. Rick H.
      • monica
        • Oct 2013
        • 15169
        #78
        ta for asking ,as you do never know,i have seen some timme to time,just a matter of looking,
        Hi,Rick i have seen theses preiser one ,that can be very costly ,as well,sometime they popup from china,in some ebay sites,:smiling:
        • Gern
          • 9226
          #79
          I got a question. I know work on this has slowed a bit, but it hasn't stopped. I sprayed the interior about 10 days ago with Vallejo Model Air 046 Pale Blue Grey, no primer.
          I'm just masking the interior ready to do the outside. Does anyone know why the interior paint is still tacky to the touch?
          • JR
            • May 2015
            • 18273
            #80
            Morning or good evening Dave.
            Paint problem is as strange as this build :tongue-out3:. Very concerned about Chris, is he the one with cabin fever ? Either that or lack of Marmite !:nerd::smiling::smiling2::smiling3:
            As to why it's is still tacky, has it gone on well or has the surface pooled ? Could be the plastic, or grease.
            • Mini Me
              • Jun 2018
              • 10711
              #81
              Turn the heat up Dave...........when I was young living in The Rainy Damp State of Oregon I used to park my fresh painted models on top of the hot water heater for the day........worked every time. Rick H.
              • Gern
                • 9226
                #82
                It went on well enough John and the surface is nice and smooth. But I think I'm cursed when it comes to painting. Just used some Model Colour in my A/B for the exterior of my van. Then had to spend 40 minutes cleaning my A/B. I found paint everywhere! I thinned it with about 30% Vallejo thinner and gave it a good mix in the cup with a brush. Just before I finished coverage, my A/B got a bit spluttery but I managed to complete the painting.
                When I came to clean out my brush I found a thick goopy mass of paint about the consistency of our favourite substance - Marmite (See! Marmite does have it's uses! Even if it's only to describe the consistency of goop!) - in the front of the brush. That's clearly an issue with the paint, but all the rest is down to my A/B!
                I found paint all around the outside of the barrel by the trigger; the needle, the trigger itself, the air feed valve from the compressor and the clamping screw for the needle were also covered in paint. I even found paint on the back end of the needle! Even I know that isn't supposed to happen and I had a fairly lengthy conversation here some months ago with a similar issue. There's a seal in the main body of the A/B just in front of the trigger that's supposed to stop paint getting back to the trigger mechanism - obviously it's not working. I'm going to contact John and see if he can get one for me, but I have vague recollections of H&S denying the existence of the seal, or summat.
                I think I'm doomed to failure with any tools more complicated than a hammer! Nothing to do with me being a ham fisted oaf - it's the Gods. They just don't like me!
                • Gern
                  • 9226
                  #83
                  We've been having a mini heat wave over the last few days - which is why my build has slowed down, it's been just too warm (and it didn't help the other day when my shower broke down. I put the hot water on for a bath instead and found that the only way I could get hot water was if the central heating was turned up full! Something to do with a sticky valve according to the heating engineer) - so I don't think that's the problem Rick.
                  • Gern
                    • 9226
                    #84
                    I think I'm the one who's supposed to have cabin fever, but don't ask me - my brain's gone ^**(+£$$^??
                    • boatman
                      • Nov 2018
                      • 14498
                      • christopher
                      • NORFOLK UK
                      #85
                      ME havin cabin fever John im as strange as you marmite lovers nothin up with mememmemememe
                      chris
                      • JR
                        • May 2015
                        • 18273
                        #86
                        Dave there is inner seal, just inside the front of the AB body. You would need a special tool which is inserted from the rear when the needle assy is removed. A small screwdriver is supposed to work, like those plastic box sets, which contain several different sizes, the one I had I couldn't get the head in further enough to remove the screw. I'll have a look later for the code no of the seals and the tool.
                        • JR
                          • May 2015
                          • 18273
                          #87
                          Dave .
                          The Harder & Steenbeck Needle Seal Tool is specifically designed for the removal & installation of the main needle seal (sometimes referred to as the needle bearing) from your airbrush.
                          The tip of the tool fits through the needle seal retaining screw & the screwdriver tip engages in it, unscrewing then removes the screw & seal in one operation, the seal keeping the screw in position & preventing it's loss. To refit, the old seal is removed from the tip of the tool & replaced, then the tool is simply re-inserted & the screw tightened. The barrel of the tool is a close fit to the airbrush body which correctly aligns the tool for use & prevents the possibility of cross-threading.
                          Suitable for;
                          • Ultra
                          • Focus
                          • Evolution
                          • Evolution Silverline
                          • Evolution CRplus
                          • Evolution ALplus
                          • Grafo
                          • Infinity
                          • Infinity CRplus
                          Needle Seal (123450)
                          REF: 123450
                          This is for the Ultra. I don't know which ab you have so check your leaflet that came with it.
                          If John hasn't got any stock go to .
                          Comprehensive range of spares for the Harder & Steenbeck Ultra, Evolution, Grafo, Infinity & colani airbrush ranges, needles, nozzles, seals, springs, fittings.........
                          HTH.
                          • Gern
                            • 9226
                            #88
                            Good stuff John, thanks! I'm betting it's gonna cost me an arm and a leg but I'll find out.
                            • JR
                              • May 2015
                              • 18273
                              #89
                              Not too bad Dave , £ 7.69, £ 1.40 For the seal, pluss postage.
                              • minitnkr
                                Charter Rabble member
                                • 7551
                                • Dayton, OH USA
                                #90
                                Is that 7.69 for the arm & 1.40 for the leg? Bed #105
