Oldie but goodie Tiger I
  • Strenko J
    • May 2018
    • 752
    • Joe
    • Pittsburgh PA
    I chose to break out an oldie but goodie that I have had in my stash for many many many ,,,,yes many ..years now and decided to “bling“ it up a little since this kit has had numerous updates through Tamiya over the years. This is the very old motorized Tiger I tank as the base model.. with some PE, some home made zimmerrit, various scratch built items. Currently working on tracks. Here are some pics of the completed tank..primed and ready for some paint..And the bits and pieces of the tracks that need some cleanup before assembly.
    The tracks are a bit more fiddly than what I had anticipated but I want to push on and do not want to use the kit supplied ones that lack sufficient detail.Click image for larger version
ID:	1128029Click image for larger version
ID:	1128030Click image for larger version
ID:	1128031Click image for larger version
ID:	1128032Click image for larger version
ID:	1128033Click image for larger version
  • SimonT
    • 2824
    Hi Joe,
    I take it this is the one you mentioned a while back
    Love the box proudly announcing "it's motorized!" like that's a good thing :smiling5:
    Have you offset the gun or left it as the kit?
      Good to see you back at the bench Joe. Fine work so far.
        If only it were as simple as offsetting the gun, rather than having to rebuild the turret while leaving the gun in the middle
        • Steve Jones
          • 6615
          Hi Joe
          Great to see you have been busy at the bench. You've done a great job with the Zim. Looking forward to seeing the wet stuff. Doing a base and figures??
          Keep it in the short stuff mate
          • Strenko J
            • May 2018
            • 752
            • Joe
            • Pittsburgh PA
            Hi Joe,
            Simon, yep..tis the one indeed that I mentioned on your thread.. I did get a turned metal barrel and new resin Mantlet to add to the bling but did nothing more than that..
            Peter,thanks..yes it’s been a bit while finding time to actually do some of this build..very slow progress for sure
            Jakko,, wish it were that easy for sure
            Steve, yes will probably put it on a base with a few figures..suggestions ?? And I always plan to keep that little white ball in the short grass but somehow my swing doesn’t always follow the plan
            • Strenko J
              • May 2018
              • 752
              • Joe
              • Pittsburgh PA
              Finally had the chance to hit this with the hissy stick..added some chipping and first wash of dark brown to bring out some detail.
ID:	1131129Click image for larger version
ID:	1131130Click image for larger version
              • Strenko J
                • May 2018
                • 752
                • Joe
                • Pittsburgh PA
                • Strenko J
                  • May 2018
                  • 752
                  • Joe
                  • Pittsburgh PA
                  I do have to say that the wheels were very problematic in assembly and then painting as well. The plastic was very soft and would not take even primer at first… Perhaps it was the age of the kit and technology at that time for injected plastic.Click image for larger version
                  • Steve Jones
                    • 6615
                    Nice update Joe. Nice to see you have overcome the wheel issues. Lovely work all round my friend
                    • JR
                      • May 2015
                      • 18273
                      Hi Joe, always good to see your work, couldn't open that attachment 395485 unfortunately.
                      Great job on the exhaust shields, and agree with my learned friend Steve on the ZIM.:thumb2::thumb2::thumb2:
                      • minitnkr
                        Charter Rabble member
                        • 7517
                        • Dayton, OH USA
                        Some beautiful work here, Joe. PaulE
                        • monica
                          • Oct 2013
                          • 15169
                          very nice work on this tiger,love what your done,
                          must ask what did you use to make the zimmerrit, please,
                            Very nice weathering indeed Joe - very believable.
                            • Strenko J
                              • May 2018
                              • 752
                              • Joe
                              • Pittsburgh PA
                              Thanks Monica,,, it was definitely some trial and error at my first attempt on the zim...ended up using an acrylic wood filler that was thinned down and patterned using a Tamiya zim tool that I found on eBay. I liked the way it sort of broke off in some areas to Give the look of damaged zim.
