1/35 Great Wall Hobby 12. 8 cm Pak 44 .
    • 18944
    Looks great John, a real thug of a gun....
    • adt70hk
      • Sep 2019
      • 10438
      #227
      Looking good John. Nothing like a coat of primer!
      How do you find One Shot? I know it's stynlrez rebranded and a polyurethane primer like Vallejo. I currently use Vallejo for reasons I won't bore you with and so in theory should work on the same basis. Have you ever used Vallejo to compare it with?
      Thanks.
      Ps anyone else who reads this please don't clog up John's thread with your thoughts on primer comparisons. This is just for John. Sorry.
      • Steve Jones
        • 6615
        #228
        Cracking start to the wet stuff. Have you decided on the camo pattern paint scheme yet??
          Indeed Tim, wouldn't have wanted to be on the receiving end, or even standing near it when it fired.
          Thanks.
          Hi Andrew, I've used both and Amig. Out of the 3 prefer the one shot. Mixed the same, few drops of thinners and a drop of flow improver sprays ok. The only downside is that ridiculous press top, having got it everywhere the first time I used it , I now unscrew the top and gently pour it out.
          Yes I spent all of 30 seconds on that decision, certainly no camo :smiling3:, came to the conclusion that it would be as you are about to see it. !!:nerd:
            The gun's looking very nice John.
            • scottie3158
              • 14243
              • Holbeach
              #231
              John,
              Looking very nice indeed mate.
                This morning after 10: 00 sitting thinking of our friend and his family I decided to crack on. I'm sure that would have been what Simon would have wanted.
                Previously I had done a yellow top coat , taking advice from my German expert one Dude 1 aka Allen Dewire of Bamburg I left the barrel in primer. I'd even managed to half insert that muzzle brake, luckily he sported it and a dap of debonda soon had it off and push fully home.
                I had applied a coat of chipping to the Oneshot Primer , let it fully dry and put on the yellow. Unfortunately I did it too late in the day, it was going to take far to much time to do the chipping so left it.
                The next morning it was as expected far too hard to attempt any chipping, so applied a spot here and there with the brush. This morning I parted the sights up black and a touch of glass Vallejo onto the eye pieces. Then when that was dry I sprayed the whole thing in gloss varnish ready to apply some weathering.
                The base was prepared, I never bother with removing the glass, just cover it over with some cardboard, on top of that the 5mm foamboard. Ready to start the part I love best the street scene and building. [COLOR=rgb(226, 80, 65)]YES[/COLOR]
                there will be [COLOR=rgb(226, 80, 65)]FIRE [/COLOR] employed to produce the burnt roofing timbers, !! With out further ado.
ID:	1134597Click image for larger version
ID:	1134602Click image for larger version
                Now the base, other suppliers of photo frames are available .
                UHU glue applied to top of glass.
                Cardboard in place on top of the glass, and another amount of glue ready for the 5mm foam board.
                Back of frame, the upright legs has been removed, and a line of glue run around the board.
                Some weights, including two apprentice pieces that Christine late father , He had made these some years ago while teaching o taught the young moulders as test pieces.
                Right that it, comments tips abuse in any order will be gratefully received.
                Thanks for looking in.
                John.
                  Hi Peter, missed you as I started typing, thank you.
                  John,
                  Cheers Paul, glad you approve .
                    Looking great John :smiling3:.
                      Thank you Ralph.
                      • Lee Drennen
                        • 7711
                        #236
                        John. Very nice updates the seat looks very convincing
                          Cheers Lee, didn't want to over do it with it being dso new, just slightly worn.
                          • Neil Merryweather
                            • Dec 2018
                            • 5206
                            • London
                            #238
                            That gun's quite something, JR!!
                            I LOVE it
                              Very nice-looking gun
                              Iโ€™m slightly puzzled, though, by why you didnโ€™t just bend open the metal tabs on the back of the photo frame to remove everything in it and replace it by something like a bit of plywood or foam board cut to size?
                              • adt70hk
                                • Sep 2019
                                • 10438
                                #240
                                I am really loving that gun, that has come up very nicely indeed!!:thumb2:
                                I'll be looking forward to seeing how the fire experiment turns out. Personally I think pyromania should be encouraged more in our hobby!:thumb2:
                                I myself am absolutely fascinated by it and spent many hours watching the flames of our campfires during our summer holiday in Dorset. Watching how the flames changed shape, intensity, and colour was almost a spiritual experience!!
                                That said I'm not sure an ants nest at our old family home, which had defied all normal attempts to deal with it, felt about being on the receiving end of an experiment with white spirit and a match!!!
                                Keep up the good work.
