1/35 Great Wall Hobby 12. 8 cm Pak 44 .
  • Mini Me
    • Jun 2018
    • 10711
    #256
    Hobby Lobby or Michael's are good sources for cheap frames Lee......Sorry for buttin' in JR.
    Rick H.
    • grumpa
      • Jan 2015
      • 6142
      #257
      Just catching up on all this as am always on the run for something or other, not even time to work on my own stuff lately.
      But things should start slowing up as winter starts to set in proper.
      By then though I won't have a minutes peace I'm sure, as usual.
      Great work so far John, I love the big towed guns of WW2.
      Am looking in, you can be sure.
      • Lee Drennen
        • 7711
        #258
        Rick H.
        Thanks Rick I have a Hobby Lobby about 7 miles from my house.
        • Lee Drennen
          • 7711
          #259
          Yes it's pretty cheap way, always plenty of sizes and styles to pick from. I have my way of doing the infill, some people take out the glass and backing and go from there. Good luck.
          Thanks John thought about maybe foam board
          • spanner570
            • 15439
            #260
            Looking dead smart 453. Top Gun!
            Lee, foam board on it's own would be far too flexible. I'm the same as John. Usually too idle to take the thing to pieces.
            I get my picture frames from charity shops. Almost any size, dirt cheap.
              Can't be bothered really Jakko, then I'd have the glass and backing to get rid of!
              Makes sense (Though I like having a pane of glass by my workbench, so I can get wheels all touching the ground )
              • JR
                • May 2015
                • 18273
                #262
                Originally posted by Jakko
                Makes sense :smiling3: (Though I like having a pane of glass by my workbench, so I can get wheels all touching the ground :smiling3
                Ooh and you know how I struggle to do that,:smiling: I rely upon the uneven ground it's easier !
                • JR
                  • May 2015
                  • 18273
                  #263
                  Hi Jim, good to have you call in . Won't be long before your up to your waist in snow pulling city folk out of ditches again. Let the boys do that and stay in the warm .
                  Like 570 has rightly said foam board won't be strong enough, but building it up in the frame on the glass will be ok.
                  Thanks 570 , glad I'm not alone in the frame use. The annoying thing is I have loads of off cuts of 18 mm ply in the shop, the right size but don't want to drive the 14 miles to collect. Used the frames before and quite like the idea of having a edge pre done .
                  • Lee Drennen
                    • 7711
                    #264
                    Thanks John I wasn’t just going to put the foam board in I was planning to have foundation also underneath it
                    • JR
                      • May 2015
                      • 18273
                      #265
                      Sorry Lee. :nerd:
                      • JR
                        • May 2015
                        • 18273
                        #266
                        Calling the weathering down, unless of course someone thinks I've missed a bit , and by all means say. Sorry the photos might appear a little rough, they were taken rather quickly and without the stand.
                        In no particular order. If they pass I'll put a coat of flat varnish on tomorrow.
                        Used a selection of oils and some Amig enamel washes.
                        :nerd::nerd:
ID:	1135022Click image for larger version
ID:	1135023Click image for larger version
ID:	1135024Click image for larger version
ID:	1135025Click image for larger version
                        May be a pin wash again on those rivets and around that guard on the right, as shown above.
                        Thanks for looking in and following. The base is ready, had to make it wider on the frame, so no outer frame showing.Then the best part the buildings :nerd:
                        John.
                        • Si Benson
                          • 3572
                          #267
                          Evening John,
                          looking very nice:thumb2: I’d go for another pin wash if it where mine, it’s a cracking bit of kit and a dark pin wash will help highlight all those lovely details:smiling4:
                          • JR
                            • May 2015
                            • 18273
                            #268
                            Originally posted by Si Benson
                            Evening John,
                            Thanks Si, that's good enough for me. First thing tomorrow then !
                            John .
                            • minitnkr
                              Charter Rabble member
                              • 7551
                              • Dayton, OH USA
                              #269
                              Looks suitably used & abused for its short life. PaulE
                              • Lee Drennen
                                • 7711
                                #270
                                John. Nice updates looking great
