1/35 Great Wall Hobby 12. 8 cm Pak 44 .
  • Ralph
    • Oct 2020
    • 158
    #301
    Base is looking great John :smiling3:.
    • Steve Jones
      • 6615
      #302
      Outstanding JR. The skeleton of the building is well thought out and designed. The cobblestones are epic! Wonderful work all round my friend
      • JR
        • May 2015
        • 18273
        #303
        Originally posted by Peter Day
        John, can you come and do my conservatory? Great work, as always.
        Peter the answer to that is at one time yes I would, these days advise only :crying:
        Thanks Ralph :thumb2:
        Hello mate, thank you glad your approve . Did any German buildings have camo like in the UK ? How that would please you !
        • JR
          • May 2015
          • 18273
          #304
          Been thinking about saying there would be no fire , but having seen some recent photos taken from the air the majority of German factories were so heavily bombed that there is little chance that this one would have escaped either bombing or shelling .
          This therefore means a complete build and then damage, with the remains of fire damage, so Rick, Lee and Richard you better be ready !
          • Lee Drennen
            • 7711
            #305
            John. I always knew you was a big fan of a “Scorched Earth” policy the Germans had
            • JR
              • May 2015
              • 18273
              #306
              From a Russian point of view yes :smiling3: lee.
              • Strenko J
                • May 2018
                • 752
                • Joe
                • Pittsburgh PA
                #307
                Stand by, buildings and base time. Had a good day cutting out the buildings and roofing card, that will be covered later in corrugated sheets. All taken down now ready for scribing.
                Base stone sets done, tomorrow expert to get a little done on the walls, that's going to take some time scribing the bricks.
                [ATTACH=CONFIG]n1135465[/ATTACH]
                This was the updated base with the additional 65 mm approx insulation slab on. Note the cut away at the top right .
                [ATTACH=CONFIG]n1135466[/ATTACH]
                This is where the water will be.
                [ATTACH=CONFIG]n1135467[/ATTACH]
                This was yesterdays and todays result. Id cut some of the wall out yesterday but they needed rear supports
                [ATTACH=CONFIG]n1135468[/ATTACH]
                [ATTACH=CONFIG]n1135472[/ATTACH]
                Quite a lot , but this will ensure it stay upright .
                [ATTACH=CONFIG]n1135474[/ATTACH]
                Roofing card cut to the angle of the base.
                [ATTACH=CONFIG]n1135475[/ATTACH]
                All section marked and ready to take the front paper off , then cut out windows and scribe the brick work.
                Spent a couple of hrs doing the stone sets.
                [ATTACH=CONFIG]n1135476[/ATTACH]
                [ATTACH=CONFIG]n1135477[/ATTACH][ATTACH=CONFIG]n1135478[/ATTACH]
                PLeased with the first part, the river edge has been done in stone including 3 outfall pipes, need to put some drains in tomorrow.
                Comments welcome.
                stone work looks FANTASTIC what did you use to make the impressions
                • adt70hk
                  • Sep 2019
                  • 10428
                  #308
                  Can I light the match! :smiling5:
                  • JR
                    • May 2015
                    • 18273
                    #309
                    Thanks Joe. Use either a pencil ferrule with the erazor removed, or the brushes.Then shaped with a pair of long nosed pliers. Occasionally clean up the edge with a file.
ID:	1135709Click image for larger version
ID:	1135710Click image for larger version
                    Different sizes , also have some bare ferrules that can be worked into shape.
                    HTH'S
                    Yes most certainly Andrew, its quite hard to ignite the fire , take a photo and spray the water all at once.:smiling3:
                    Today I tapped all the sections in line , then marked out the windows and doors. Pin pointed the corners of the openings, I might make up a template for each window size and mark around that again before cutting .
                    Tomorrow the cutting will begin and then the paper will be removed, prior to the brick work. That alone is going to take some time.
                    Thanks for looking in.
                    John.
                    • Neil Merryweather
                      • Dec 2018
                      • 5199
                      • London
                      #310
                      [ATTACH=CONFIG]n1135709[/ATTACH][ATTACH=CONFIG]n1135710[/ATTACH][ATTACH=CONFIG]n1135711[/ATTACH]
                      HTH'S
                      [ATTACH=CONFIG]n1135712[/ATTACH]
                      John.
                      Wonderful stuff, John. Those stamps are inspired!
                      • minitnkr
                        Charter Rabble member
                        • 7551
                        • Dayton, OH USA
                        #311
                        The man with a plan. PaulE
                        • rtfoe
                          • 9100
                          #312
                          Like those stamps, John.
                          • JR
                            • May 2015
                            • 18273
                            #313
                            Kind of you to say Neil, David Neat explained how to make them in his blog from the 4 D model shop. Have to say trying to alter a round ferrule in to an oblong at the size of a scale brick is not the easiest of things, mine was more by luck than judgement !
                            Thank you Paul, but like all plans it changes as you move along
                            • JR
                              • May 2015
                              • 18273
                              #314
                              Thanks Richard. Hope your back to normal health wise.
                              • Lee Drennen
                                • 7711
                                #315
                                John. I’m with Richard that stamp idea is great
