1/35 Great Wall Hobby 12. 8 cm Pak 44 .
  • Strenko J
    • May 2018
    • 752
    • Joe
    • Pittsburgh PA
    #406
    forgot to ask last time I posted..did you have to treat the foam board with anything before painting began?
    • JR
      • May 2015
      • 18273
      #407
      No Joe, the first coat or two of the grey is just a cheap acrylic , used as a primer the just paint the rest with the washes etc as required. HTH.
      • grumpa
        • Jan 2015
        • 6142
        #408
        Just went through the hole thread from start to finish, please excuse my lateness.
        Wonderful work so far John, keep it up Buddy :thumb2:
        Jim.
          Stunning work John.
          • Si Benson
            • 3572
            #410
            Superb work John, your in your element when it comes to the building work :thumb2:
            • Neil Merryweather
              • Dec 2018
              • 5199
              • London
              #411
              Superb, John, just superb!
              I was wondering, do you not have a problem with the foam board curling up after removing one layer of card?
              • BattleshipBob
                • 6803
                • Bob
                • Cardiff
                #412
                Right load of cobblers
                You have got this building lack off to a big T, fantastic John
                • JR
                  • May 2015
                  • 18273
                  #413
                  Jim.
                  Hi Jim, glad your enjoying it. No problem with being late ever .Thank you .
                  Originally posted by Paintguy
                  Stunning work John.
                  Thanks Andy.
                  Think your right Si, it's the only time I really feel I know what I'm doing !
                  Thanks Neil. Yes it does try to curl, but I used to then stick another sheet to the paper side and counter it. This time I've found that placing heavy weights ( those steel bars about 150mm x 25 x 25. seem to cure it. Using another sheet of board seemed to be a rather expensive way,suppose I could have used a cheaper foam board and not Kappa for the back .
                  What do you do in this case ?
                  Right it is Bob:smiling3: as I said to Si it's the only time I know what I'm doing :nerd:
                  JOHN .
                  • adt70hk
                    • Sep 2019
                    • 10428
                    #414
                    Great work again John.
                    ATB
                    • rtfoe
                      • 9100
                      #415
                      John, you have found the right material to work your magic on and making inroads with leaps and bounds. Very much like your cobble stones and brick work.
                      • Mini Me
                        • Jun 2018
                        • 10711
                        #416
                        There you go JR.........out of the mouth of babes......your bricks and cobbles are a wonder! Rick H.
                        • JR
                          • May 2015
                          • 18273
                          #417
                          ATB
                          Thanks Andrew.
                          Coming from someone with your skill Richard I'm chuffed . Thank you.
                          Thanks Rick, perhaps I should just do buildings !
                          John.
                            • 15745
                            Hi John
                            Using pigments for the mortar and between the cobbles is a clever idea and has worked well. The balsa wood framing is good. Do you have problems with the wood splitting when pinned?
                            • JR
                              • May 2015
                              • 18273
                              #419
                              Originally posted by Jim R
                              Hi John
                              Hi Jim.
                              When the mortar mix dried in some places it was none existent, in others it is there. Still it gives a good variation with out trying :smiling3:.I'd use it again, had thought of soil from the garden. I have some dried and M/W 'd. Think it would need to be crushed again with a pestle and mortar. Some people have used coloured tile grout with success.
                              You have to be careful with the pins, these are new and quite sharp as I can testify
                              But being sharp they cause little splitting. Of course these sections are quite thin, that we'll make a difference.
                              HTH's
                              • outrunner
                                • Apr 2019
                                • 2420
                                #420
                                Coming along nicely John, and I also can testify to the sharpness of model pins from when I used to build R/C aircraft using balsa. (ouch!)
                                Andy.
