1/35 Great Wall Hobby 12. 8 cm Pak 44 .
    • 18932
    Hi John
    Just had a good catch up here. The building is looking fantastic, definitely something you have a real talent for. As to etch primer, I’m not sure to be honest, but it would seem logical that the primer is cellulose based, and the etch component microabrades the surface to enable a better mechanical bond between the primer and the metal. Most sheet metals have extremely smooth surfaces and will not allow paint to generate a good mechanical bond. and etching overcomes this. I’m going to look it up now, because you’ve piqued my interest :tongue-out3:
      • 18932
      There you go John....
      Etch Primer is a paint that is designed to physically bond itself to the substrate to which it is applied, usually a colour will be added to the Etch Primer.
      • JR
        • May 2015
        • 18273
        #453
        Very nice John really taking shape.
        Thanks Paul.
        Stonking stuff, John!
        what did you use for the guttering?
        Hi Neil, used some 5mm half round styrene. Know lots of people use drinking straws cut down but quilts like the styrene .
        Oh thanks Tim, great article, just had a read before replying. No wonder then the brush cleaning was in cellulose then . See their cellulose is £8 .75 for 250 ml, as I only want some for cleaning the brush I'll go to Halfords at £ 5.50 .
        • Si Benson
          • 3572
          #454
          Evening John,
          So your into some plumbing now are you!?
          Wood work looks very good mate :thumb2:
          • Mini Me
            • Jun 2018
            • 10711
            #455
            Coming on strong there JR..........really looks the Dog's :thumb2:
            • JR
              • May 2015
              • 18273
              #456
              Originally posted by Si Benson
              Evening John,
              :smiling2::smiling2: Has been known Si, thank you.
              Hi Rick thank you.
              Spent to day assembling the down pipes into the gutters, painted the cills, armored car for the Simon T Memorial Build.
              All very time consuming so not a lot to show !
              Also using some drinking straws for smaller pipe runs, donated by Christine.
              Found that a old Christmas chocolate box filled with sand is perfect for a sturdy support for the clip on tool.
              John.
                • 15744
                Hi John
                Building is brilliant. Love the guttering and pipes.
                Have you seen THIS stuff? I like VMS stuff.
                • JR
                  • May 2015
                  • 18273
                  #458
                  Originally posted by Jim R
                  Hi John
                  Thanks Jim, yes I saw it on Utube the other day, bet it will be pricey.
                  I have some de-bonda from Toolstation which must be the same stuff .Costs £1.85 ! Plus they have various other CA GLUES.
                    More great work John. You're obviously having a ball.
                    • JR
                      • May 2015
                      • 18273
                      #460
                      Yes indeed I am Peter,thanks for looking in .
                      • Steve Jones
                        • 6615
                        #461
                        Awesome work. You must be having a ball! It's all going so well. Great use of straws. Looking forward to seeing the next update. Keep up the great work my friend
                        • JR
                          • May 2015
                          • 18273
                          #462
                          Thank Steve, primed and ready for top coat when I can decided what colour to use steel wise.
                          • outrunner
                            • Apr 2019
                            • 2420
                            #463
                            Cracking building work John, looking good.
                            Andy.
                            • JR
                              • May 2015
                              • 18273
                              #464
                              Andy.
                              Thanks Andy, and for staying with it !
                              • minitnkr
                                Charter Rabble member
                                • 7551
                                • Dayton, OH USA
                                #465
                                A pipefitter as well as a joiner & mason. Looking good. PaulE
