1/35 Great Wall Hobby 12. 8 cm Pak 44 .
  • KarlW
    • Jul 2020
    • 1522
    #46
    Originally posted by Jakko
    T-55, IIRC. There’s also the the Kelly’s Heroes ones, which were T-34-based but looked quite convincing. Even cooler with those, though, is that someone built a diorama that featured in some 1980s Tamiya catalogue based on the movie, with a “Tiger” made in the same way.
    Warlord games do a Kellys Heros set with Oddballs Sherman and that Tiger available in 1/56.
    • Steve Jones
      • 6615
      #47
      ... and hes off! A nice looking kit sir. Looks like it is going to together well. Look forward to seeing your next update.
        Originally posted by Pete Low
        Broadsword calling Danny boy..... Broadsword calling Danny boy "oops" broadsword calling Christine update on "The Bench" use frequency 10 at 2100 hours.... Over and out.
        Sorry Christine didn't reply Broadsword she went to bed just before then.
        Bench is still tidy though !
        Hi mate , thanks, unfortunately a very small light section went flying into the air, never to be seen again. After crawling around for sometime I gave up It's only about 2mm in size, too small for me to scratch. Had a go at some PE earlier, of course would have to be formed over some cover, I part is half on !
          Evening all.
          Not a bad day at the bench, slow with the parts being very small and quite a few in a subassembly. Did spend some time watching part of the "White Tiger " film that Peter Day mentioned, thanks Peter I'm really enjoying it.
          Agree with Wouter and Jakko not a very convincing Tiger .:smiling2:
          Working still on the chassis on the axle part.
          The above is the upper ssection. Very little cleaning apart from the cut off points.
          The above curved parts would have been better glued in after the part with the two holes in it. Might add some more glue and try to move them down when the whole assembly is built .
          C&C Welcome, thanks for looking in .
          • Steve Jones
            • 6615
            #50
            That's a nice looking sub section there mate. A nicely detailed kit. Keep up the the good work and don't strain your eyes too much
              Thanks Steve, trying not to, so working in short lengths.
              Some very small parts again today, all part of the axle assemblies.
              Ok not that small for many of you, but that fork and the pins had mating points, with some good lighting the optivisor and a lot of luck two of them fitted. (Yes I did clean off the attachment point )
              Very pleasing when those bars fitted, again there are two more of those small connectors to be fitted tomorrow.
              With such a small assy I'm having to attach one or two parts and leave until the glue sets. Although time consuming it's rewarding to do something this complex. ( Well it is to me :smiling3: )
              C&C Welcome, and thanks for looking in.
              • BigGreg
                • 2186
                #52
                looking good... :-) :-)
                  Blimey - micro surgery John. Well done.
                  • Neil Merryweather
                    • Dec 2018
                    • 5206
                    • London
                    #54
                    this is looking the dog's doodahs ,John!
                      • 15798
                      Hi John
                      Great start. Guns always seem to have very small, fiddly parts. Looks to have some nice detail. I'm sure you're right in taking it steady and letting each stage dry.
                      • scottie3158
                        • 14243
                        • Holbeach
                        #56
                        John,
                        Lovely neat work mate, taking your time is really paying off.
                          Thanks Greg.
                          It is indeed Peter.
                          Cheers Neil.
                          Originally posted by Jim R
                          Hi John
                          Hi Jim. Having something else to do as the glue dries is a must. Greenhouse, then bench , and so on .
                          John,
                          Thanks Paul.
                          • minitnkr
                            • 7568
                            • Dayton, OH USA
                            #58
                            Well done Dzohn. Some real engineering here in an effort to save weight & deploy time, but does complicate things. PaulE
                              Thanks, think only the Germans could come up with something as complex Paul.
                              • minitnkr
                                • 7568
                                • Dayton, OH USA
                                #60
                                Have to agree. MB would never put 4 fasteners where 8 would do. Porsches & Audis were much more normal. PaulE
